Hi all,
I have a part, bounding box about 50x50x25 mm, intended to be CNC machined in 7075 Al. The part is also intended to be epoxy-bonded to a composite piece (a ski) using 3M Weld D460. I have a small mill, but it's not practical for this material and dimensions.
So I would like to print it first at Shapeways, either in their Al or a strong plastic. I have ordered dozens, if not hundreds, of parts from Shapeways, but never before had to think about strength and bonding. The cost of printing in Al appears similar to CNC-ing, and I would still have to finish the key surfaces on my desktop mill.
So, I am thinking to print in plastic first, as it's supposed to be much cheaper than printing in Al. It also would be great to do minimal functional testing. Parameters I care about are yield and tensile strength (e.g. similar to Delrin, polycarbonate), milling to within 0.005, better to within 0.001" (to match surfaces and to insert stainless pins), and bonding via epoxy. Shapeays cheapest strong plastic is 'chippy', so I am pretty sure that one is a non-starter. Any other suggestions?
Thank you in advance
