iSolar
Back in Dec. 25 2009 i published this concept on Youtube:
https://www.youtube.com/watch?v=gT6Lsl9aaHc
Back then i was clueless when it comes to 3D printing.. i had no idea that some day i could design it and make it a real thing..
Actually that can be said for many of my other ideas and concepts which you can see on
my Youtube channel and on my
Accessories for Apple's products section on my shop.
So, the idea is simple - 4 small solar panels (dealextreme.com) each producing 5.5V & 130mA connected to each other in parallel to produce a total of over 500mA - which is basically the amount of current you get from any regular USB on your PC - only this power comes from the Sun - free & saves the environment.
As you can see on the concept video - its compact , swivels to open and close , fits in your pocket easily, you connect your USB cable in the middle and start charging your gadgets & Apple's iDevices immediately
- meaning there is no internal battery that needs to be charged for 10 hours.. before you can use this solar charger
- just point towards the sun and charging begins immediately.
Also no fancy electronics - any one with a bit of soldering experience can do it.
Ok, so i had in mind to publish this DIY project on instructables.com and perhaps drive traffic of Do IT Yourself enthusiasts to shapeways..
But that can wait - the following print came a little bit fused ..
The first swiveling part is OK yet the others were fused to the base though 0.5mm gap was used - so its back to the drawing board to either increase the gaps to 0.7mm or redesign it from scratch so each panel holder is assembled manfully one on top the other - then the last part , the USB "cork", sits on top all and closes the unit.
Back to the drawing board - will update this thread.
Cheers
