Designing dice for dice snobs
Re: Designing dice for dice snobs [message #18262 is a reply to message #18250 ] Thu, 23 September 2010 19:17 UTC Go to previous messageGo to next message
mctrivia wrote on Thu, 23 September 2010 18:41
steel minimum diameter is 3mm with 1mm clearance
only if it's over 5cm in height.. that's not the case here nor in any steel pendant/ring you can find on shops
Shapeways has to give a serious thought on the canceling process - i've asked support to consider the idea that a shop owner will receive a window of 24-72 hours to fix his/her model and re-upload (much like a co-creator process) before canceling the order and issuing a coupon to a confused customer.
If shop owner fixed the issue and re-uploaded the model but there is a cost difference it will be deducted from his markup.
The current cancellation process fails to bring that customer to re-order that design..
A shop owner looses that customer and most likely not only for the failed order.. Confused
http://www.3Dizingof.com
Re: Designing dice for dice snobs [message #18264 is a reply to message #18262 ] Thu, 23 September 2010 19:24 UTC Go to previous messageGo to next message
avatar gumball  is currently offline gumball
dizingof wrote on Thu, 23 September 2010 19:17
Not necessarily. I've been trying my hand at designing something and just can't seem to wrap my head around the process. I can totally understand that something might not work right the first time.
The reupload time sounds like a good idea, but if not that then I'd prefer if instead of issuing a coupon, they would just refund to Paypal. Especially since you can only use one coupon per order. I had a situation a while back where I had to choose between using a small refund or a 10% off coupon. Not cool.
[Updated on: Fri, 24 September 2010 17:54 UTC]
Re: Designing dice for dice snobs [message #18266 is a reply to message #18261 ] Thu, 23 September 2010 19:34 UTC Go to previous messageGo to next message
Drawn-Steel Hero wrote on Thu, 23 September 2010 19:12
Depends on the size. Rule of thumb seems to be that 3mm is the minimum accepted wall thickness on any model over 5x5x5cm, but on smaller models they will accept down to 1mm.
I had a couple of my I Ching trigram pendants printed in steel. They have two 1.5mm diameter rods serving as the threading loop, and suspending the actual trigram, and they printed just fine.
Andy
likewise, the Leo Pendant i made for my daughter was total 3mm deep, but some of the segment walls are under 0.5mm
I've seen it written here somewhere that as long as the item is less than 50mm diameter the 1mm wall thickness is fine... what i'm wondering is if those rules take into account 3 dimensions, because a minimum of 27 cubic mm (3x3x3mm) on any part of a model is going to be chunky and very expensive... and is the 50mm diameter in 2 or 3 dimensions?
I understand why my chained die failed (not structurally sound for the top face when printed) and it is probably the same reason for the extruded... i have yet to have a 'falied' notice for my own order, but have had 'Your model has been cancelled' email
& thanks to Youknowwho4eva for the lnk to the paper dice... that's helped me loads Smile
& thumbs up to Gumball... i suppose i'm like a kid here, i read the rules and am trying to find the real limits
Re: Designing dice for dice snobs [message #18295 is a reply to message #16979 ] Fri, 24 September 2010 15:36 UTC Go to previous messageGo to next message
I regret to inform that the beautiful Swirl Dice can not be 3D printed in metal
The reason:
"DISTORTS REALLY BAD"
"After being in the furnace for along time, some parts cool down faster than other and that can create distortion and in case with your model, it breaks." Confused
So i had to remove the metal material from the model's page.
Those who ordered it - the orders were canceled you are all welcome to re-order it in a different material.
Cheers..
Dizingof
Edit: model was thickened and is now printable in metal.
[Updated on: Sun, 03 October 2010 08:30 UTC]
Re: Designing dice for dice snobs [message #18470 is a reply to message #16979 ] Tue, 28 September 2010 02:25 UTC Go to previous messageGo to next message
Hey Shapers,
My 52nd dice - Aztec D6 Dice
Inspired by the unique architectural skills of the ancient Aztec.
index.php?t=getfile&id=5267&private=0
Dizingof
[Updated on: Tue, 28 September 2010 02:25 UTC]
Re: Designing dice for dice snobs [message #18477 is a reply to message #16979 ] Tue, 28 September 2010 07:27 UTC Go to previous messageGo to next message
And... here is another Ancient dice , this one from Egypt.
Ancient Egyptian D6 Dice
index.php?t=getfile&id=5268&private=0
http://i53.tinypic.com/2usaihy.jpg
http://i52.tinypic.com/dzfjwx.jpg
Dizingof
Re: Designing dice for dice snobs [message #18565 is a reply to message #16979 ] Wed, 29 September 2010 22:35 UTC Go to previous messageGo to next message
I have to say dice creativity just bursting out of me , hope it continues
Here are 3 new dies:
Pair of SandStone D6 dice
Using the unique properties of the Sandstone material look&feel:
index.php?t=getfile&id=5281&private=0
Caged D6 Ball
http://i53.tinypic.com/rvcys4.jpg
Floating D6 Dice
http://i56.tinypic.com/nnn11f.jpg
http://i53.tinypic.com/ohqse9.jpg
Dizingof
Re: Designing dice for dice snobs [message #18593 is a reply to message #18565 ] Fri, 01 October 2010 06:42 UTC Go to previous messageGo to next message
Floating D6 Dice - Very Nice!!
Re: Designing dice for dice snobs [message #18594 is a reply to message #18593 ] Fri, 01 October 2010 07:51 UTC Go to previous messageGo to next message
Shapeways Crew
Dizingof, a question: what prevents the figures from exiting from the frame of the die?
[EDIT] Understood. The lateral figures prevent the whole structure from falling...
[Updated on: Fri, 01 October 2010 08:46 UTC]
Re: Designing dice for dice snobs [message #18595 is a reply to message #18593 ] Fri, 01 October 2010 08:16 UTC Go to previous messageGo to next message
gumball wrote on Fri, 01 October 2010 06:42
Thanks gumball.
Here are some new ones:
Wizard's D4 Dice
http://i1080.photobucket.com/albums/j322/dizingof/WiziardsD4dice445.jpg
http://i1080.photobucket.com/albums/j322/dizingof/WiziardsD4dice447.jpg
Wizard's D8 Dice
http://i1080.photobucket.com/albums/j322/dizingof/WizardsD8Dice452.jpg
Wizard's D10 Dice
http://i1080.photobucket.com/albums/j322/dizingof/WizardsD10Dice455.jpg
Quatro D4 Dice
http://i1080.photobucket.com/albums/j322/dizingof/QuatroD4dice460.jpg
Trio D3 Dice
http://i1080.photobucket.com/albums/j322/dizingof/TrioD3Dice466.jpg
http://i1080.photobucket.com/albums/j322/dizingof/TrioD3Dice468.jpg
Wizard's D12 Dice
http://i1080.photobucket.com/albums/j322/dizingof/WizardsD12Dice473.jpg
Star D8 Dice
http://i1080.photobucket.com/albums/j322/dizingof/StarD8Dice477.jpg
Art Deco D4 Dice
http://i1080.photobucket.com/albums/j322/dizingof/ArtDecoD4Dice481.jpg
Dizingof
Re: Designing dice for dice snobs [message #18657 is a reply to message #16979 ] Sun, 03 October 2010 08:48 UTC Go to previous messageGo to next message
they keep coming !
Half moon D8 Dice
http://i1080.photobucket.com/albums/j322/dizingof/HalfmoonD8Dice490.jpg
http://i1080.photobucket.com/albums/j322/dizingof/HalfmoonD8Dice492.jpg
Half moon D20 Dice
http://i1080.photobucket.com/albums/j322/dizingof/HalfmoonD20Dice495.jpg
http://i1080.photobucket.com/albums/j322/dizingof/HalfmoonD20Dice497.jpg
Half moon D10 dice
http://i1080.photobucket.com/albums/j322/dizingof/HalfmoonD10dice501.jpg
TeeVee Dice
http://i1080.photobucket.com/albums/j322/dizingof/TeeVeeDice516.jpg
http://i1080.photobucket.com/albums/j322/dizingof/TeeVeeDice518.jpg
Shooting Star D6
http://i1080.photobucket.com/albums/j322/dizingof/ShootingstarD6520.jpg
http://i1080.photobucket.com/albums/j322/dizingof/ShootingstarD6521.jpg
Cheers
Dizingof
Re: Designing dice for dice snobs [message #18709 is a reply to message #18657 ] Tue, 05 October 2010 08:20 UTC Go to previous messageGo to next message
i like the tv die. I just added 4 new dies myself.
3/4" Puzzle Die. Stores a micro SD Card Inside - Not for sale yet I am getting printed and want to make sure it works first. It is a pretty tiny space to squeze the mechanisms into.
The other 3 are available now and all perfectly weighted.
Floating Face Die
Floating Face Spiked Die
Floating FaceClawed Die
index.php?t=getfile&id=5328&private=0
Re: Designing dice for dice snobs [message #18779 is a reply to message #16979 ] Thu, 07 October 2010 05:30 UTC Go to previous messageGo to next message
Hey all,
72 Dice designs and growing..
I now sliced my markup by 50% ! Enjoy !
And.. here is my latest dice, inspired by the TV series Spartacus:
Genuine roman dice
index.php?t=getfile&id=5361&private=0
Dizingof
Re: Designing dice for dice snobs [message #19176 is a reply to message #16979 ] Fri, 15 October 2010 18:13 UTC Go to previous messageGo to next message
Hey all
I was asked by a youtube viewer if i could create a template for him to create his own D6 dice by uploading 6 pictures of his own graphics for each side of the dice...
I thought now that is a cool idea... so i made this co-creator:
Customize your very own D6 dice design with anything you have in mind and for any game you invent.
http://www.shapeways.com/model/165727/customized_dice.html?g id=sg28396
ex:
index.php?t=getfile&id=5490&private=0
Dizingof
Re: Designing dice for dice snobs [message #19209 is a reply to message #16979 ] Sat, 16 October 2010 07:20 UTC Go to previous messageGo to next message
This one already made a sale before i announced it here... Cool
Synergy D12 Dice
index.php?t=getfile&id=5503&private=0
Dizingof
Re: Designing dice for dice snobs [message #19214 is a reply to message #19176 ] Sat, 16 October 2010 09:56 UTC Go to previous messageGo to next message
Shapeways Crew
I already did months ago a customizable Sandstone D6 (well two actually) and I just sold none of them Sad
Seems that as far as dice are concerned, metal rules...
[Updated on: Sat, 16 October 2010 09:57 UTC]
Re: Designing dice for dice snobs [message #19218 is a reply to message #19214 ] Sat, 16 October 2010 10:54 UTC Go to previous messageGo to next message
Magic wrote on Sat, 16 October 2010 09:56
I agree, did you notice someone bookmarked your design? -
makes you wonder what the ratio of bookmark to actual sale is..? Confused
My tip is this: try shuffling the main picture of your bookmarked designs - this way it could get the attention of the customers who bookmarked it next time they log in.
Here is a new beauty i just finished .. Diamond D6 Dice
index.php?t=getfile&id=5504&private=0
http://i1080.photobucket.com/albums/j322/dizingof/DiamnodD6Dice587.jpg
http://i1080.photobucket.com/albums/j322/dizingof/DiamnodD6Dice589.jpg
If anyone has the budget to cast it in Silver message me i'll drop my markup to $0 ! Cool
Dizingof
Re: Designing dice for dice snobs [message #19229 is a reply to message #19209 ] Sat, 16 October 2010 16:20 UTC Go to previous messageGo to next message
Your Synergy D12 die is cool... do the opposites add up to 13?
Re: Designing dice for dice snobs [message #19235 is a reply to message #16979 ] Sat, 16 October 2010 19:35 UTC Go to previous messageGo to next message
2 new dices
Circles D8 Dice
http://i1080.photobucket.com/albums/j322/dizingof/CirclesD8Dice593.jpg
http://i1080.photobucket.com/albums/j322/dizingof/CirclesD8Dice594.jpg
Infinity D8 dice
http://i1080.photobucket.com/albums/j322/dizingof/InfinityD8dice597.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InfinityD8dice600.jpg
Dizingof
Re: Designing dice for dice snobs [message #19251 is a reply to message #16979 ] Sun, 17 October 2010 07:13 UTC Go to previous messageGo to next message
Well I have been having problems with any models with movable parts not working. So while I wait for my most recent attempt at a model with moving parts here is my crazy new die.
Prism Dieindex.php?t=getfile&id=5520&private=0
8863 faces is a little crazy but it looks pretty cool.
  • Attachment: prism.jpg
    (Size: 40.92KB, Downloaded 1268 time(s))
Re: Designing dice for dice snobs [message #19291 is a reply to message #16979 ] Mon, 18 October 2010 10:28 UTC Go to previous messageGo to next message
Heya
2 new dies.
Razor D6 Dice
http://i1080.photobucket.com/albums/j322/dizingof/RazorD6Dice606.jpg
http://i1080.photobucket.com/albums/j322/dizingof/RazorD6Dice607.jpg
Squares - D12 Dice
http://i1080.photobucket.com/albums/j322/dizingof/SquareD12Dice622.jpg
http://i1080.photobucket.com/albums/j322/dizingof/SquareD12Dice623.jpg
Cheers
Dizingof
Re: Designing dice for dice snobs [message #19294 is a reply to message #19291 ] Mon, 18 October 2010 11:12 UTC Go to previous messageGo to next message
avatar Drawn_Steel_Hero  is currently offline Drawn_Steel_Hero
Just a thought, Dizingof, but wouldn't your Squares die have a high probability of landing between numbers?
Andy
Re: Designing dice for dice snobs [message #19295 is a reply to message #19294 ] Mon, 18 October 2010 11:43 UTC Go to previous messageGo to next message
Drawn-Steel Hero wrote on Mon, 18 October 2010 11:12
Andy
If you rotate the dice in the 3D viewer you'll see that the cubes are actually angled toward the location of a number - so gravity will make it land on a number where there is a wider area to land on.
Re: Designing dice for dice snobs [message #19297 is a reply to message #19295 ] Mon, 18 October 2010 12:39 UTC Go to previous messageGo to next message
Oh, I could see that they were angled; I was just thinking it was a lot of extra flat faces to potentially land on, even if they are a little smaller than the number faces. I wondered if it might be an idea to slightly curve the faces of the squares to help make sure the die 'steers' onto one number or another.
Andy
Re: Designing dice for dice snobs [message #19318 is a reply to message #16979 ] Mon, 18 October 2010 18:31 UTC Go to previous messageGo to next message
My latest die, to compliment the Stepped Die D6
'Step Twin - stepped edge die D6'
http://www.stop4stuff.com/shapeways/stepped-edge-d6/images/stepped-edge-die-step-twin-d6.jpg
As yet, untested in any material (i'll be ordering in stainless soon)
Re: Designing dice for dice snobs [message #19358 is a reply to message #19318 ] Tue, 19 October 2010 04:40 UTC Go to previous messageGo to next message
I have been going through and double checking my math on all my dice. Now all my dice are perfectly waited to have a center of gravity in the center of the die(+-10um)
I have also made a new die. I call it the grid Die:
index.php?t=getfile&id=5544&private=0
  • Attachment: grid.jpg
    (Size: 31.62KB, Downloaded 1175 time(s))
[Updated on: Tue, 19 October 2010 04:41 UTC]
Re: Designing dice for dice snobs [message #19398 is a reply to message #16979 ] Tue, 19 October 2010 16:16 UTC Go to previous messageGo to next message
@mctrivia
may i ask why aren't you rendering your models?
it adds alot to a potential customer .
there are plenty free renderers out there
Re: Designing dice for dice snobs [message #19400 is a reply to message #19398 ] Tue, 19 October 2010 16:21 UTC Go to previous messageGo to next message
the reason because i like the job shapeways does better then anything i have found so far. for some things i have temporarily made a extra model to render a different angle.
i do like your models better though. what do you use?
Re: Designing dice for dice snobs [message #19401 is a reply to message #19297 ] Tue, 19 October 2010 16:37 UTC Go to previous messageGo to next message
Drawn-Steel Hero wrote on Mon, 18 October 2010 12:39
Andy
Thats a good idea i will look into it.
@mctrivia
http://www.independentdeveloper.com/archive/2007/10/17/free_ standalone_rendering_soft
Re: Designing dice for dice snobs [message #19403 is a reply to message #19398 ] Tue, 19 October 2010 16:40 UTC Go to previous messageGo to next message
@dizingof
sorry to jump in on a q asked of someone else
I'm of the view that even though a render can get near to the finished item delivered to the customer, the render doesn't actually represent the finished product particularly with plain stainless items.
But having said that, you do get very close and your silver coloured Floating D6 (in message #18565) looks almost just like Alumide.
Re: Designing dice for dice snobs [message #19405 is a reply to message #16979 ] Tue, 19 October 2010 17:04 UTC Go to previous messageGo to next message
Thanks, if you've noticed, only recently i started to apply textures on my rendered models.... i've tested diferent textures that can match the final 3d printed models looks - sandstone or metal , like this one:
Print-A-Coaster
i'm still perfecting it,
i think it adds a lot to the sale process.
Re: Designing dice for dice snobs [message #19423 is a reply to message #19405 ] Wed, 20 October 2010 02:12 UTC Go to previous messageGo to next message
Added another die.
4 Dimensional D48.
http://www.shapeways.com/model/167274/4d_d48.html
index.php?t=getfile&id=5558&private=0
As for rendering I have pov-ray. Use it for simulating PCB before manufacturing. Will see if I can figure out how to use to simulate stl files.
  • Attachment: 4d-d48-1.jpg
    (Size: 176.40KB, Downloaded 1117 time(s))
Re: Designing dice for dice snobs [message #19424 is a reply to message #19423 ] Wed, 20 October 2010 02:51 UTC Go to previous messageGo to next message
OK, that's pretty twisted. Smile
Re: Designing dice for dice snobs [message #19425 is a reply to message #19424 ] Wed, 20 October 2010 02:55 UTC Go to previous messageGo to next message
i love 4D shapes. I just never thought of making a 4D die before. Thought about making it a D8 that needed to be rolled onto a 3D surface but the shadow just did not look good at all and it was impossible to render the 1 side as it would be inverted.
[Updated on: Wed, 20 October 2010 02:57 UTC]
Re: Designing dice for dice snobs [message #19426 is a reply to message #19425 ] Wed, 20 October 2010 03:11 UTC Go to previous messageGo to next message
mctrivia wrote on Wed, 20 October 2010 02:55
Heh, I just left a comment to that effect (about landing on a cell) on the product page. Fair enough.
One of these days I'll give myself permission to blow $65 on one of Bathsheba's 120-cell models, my favorite polytope.
Re: Designing dice for dice snobs [message #19427 is a reply to message #19426 ] Wed, 20 October 2010 03:20 UTC Go to previous messageGo to next message
that is a beautiful model.$372 in gold plated steal ouch
Re: Designing dice for dice snobs [message #19447 is a reply to message #16979 ] Wed, 20 October 2010 15:55 UTC Go to previous messageGo to next message
It has come to my attention that though both sides of each face can be landed on they are still the same face when looking at in the 4th dimension. so i have made http://www.shapeways.com/model/167487/4d_d24.html to correct this.
index.php?t=getfile&id=5562&private=0
  • Attachment: 4d-d24.jpg
    (Size: 32.04KB, Downloaded 1083 time(s))
Re: Designing dice for dice snobs [message #19450 is a reply to message #19447 ] Wed, 20 October 2010 16:42 UTC Go to previous messageGo to next message
avatar Charmed_Life_Designs  is currently offline Charmed_Life_Designs
Woah. That thing just blows my mind. *head explodes*
When in doubt... Duct tape!
Re: Designing dice for dice snobs [message #19452 is a reply to message #16979 ] Wed, 20 October 2010 16:56 UTC Go to previous messageGo to next message
Unfortunatly your 3D shadow will only land showing 6 possible solutions that the actual 4D die could land on. Also I believe every face could land on either side doubling the possibilities in 4D space.
Re: Designing dice for dice snobs [message #19454 is a reply to message #19452 ] Wed, 20 October 2010 17:12 UTC Go to previous messageGo to previous message
yes the 3d model will only land on 6 sides. if it was printed in 4d though it could land on all 24 sides.
yes it is possible to land on each side of the face which is why i designed a d48 first. however each side of the face is still the same side(envision an edge on 2d die. it can land on 2 or 6 but it is still the same edge between them.
Pages (10): [ «    1  2  3  4  5  6  7  8  9  10    »]
Previous Topic:DOTA 2 - Weaver Statue!
Next Topic:World War 2 Sea Mine
