Home » Community » Instructions »
HO narrow gauge trucks
HO narrow gauge trucks [message #49495] Wed, 06 June 2012 22:04 UTC
avatar pinddle  is currently offline pinddle
Some general notes about my trucks.
These trucks are designed to match my rolling stock models.They should also work with those from TB Models.
They come as a block of 10 or 20 connected together,or as a pair connected to another model.They can be separated with care,the small connecting piece is discarded.
WSF-P is the recommended material,it provides a balance of strength and quality of finish.WSF is a cheaper alternative.FUD will give finer detail but needs to be handled with care as it is more fragile.
Be sure to choose the correct type to match the wheels you are using,as axle lengths vary between makes.**
If you find that the wheels don't turn freely,give the axle boxes at each end of the axle a light squeeze.Repeat until you are happy with it.
** If you have wheels with a different axle length to my designs,I can modify the design to match.
[Updated on: Thu, 19 July 2012 19:21 UTC]
Read Message
Previous Topic:HOn30 22 foot boxcar
Next Topic:Decal Sheet for HOn30 PBR Decauville #861
Goto Forum:
   Go
