Home » Support » 3D Design » Pendant w/ Thread - Need Help
Pendant w/ Thread - Need Help [message #46943] Fri, 13 April 2012 14:24 UTC Go to previous message
avatar 6516440  is currently offline 6516440
What im doing:
So I am designing a pendant to give to my girl friend. It will be the first thing I print on shapeways. The idea is the pendant will hold a message on a piece of paper wrapped around a pin inside. The pendant will be two parts and made of sterling silver. My CAD skills are more then adequate to produce the pendant, Im using solidworks.
The problem:
Im not sure what specs I should give the screw thread. So i wanted anyone's advice on the pitch, clearance and size of the thread. The nominal diameter is 4mm. The pendant is pictured both with a cross section and with out. I have read the material data sheet, but the minimum detail of 0.6mm isn't as much clarification as i would like.
Any help or feedback would be appreciated as im looking forward to doing more projects through shapeways.
  • Attachment: Pendant.JPG
    (Size: 21.04KB, Downloaded 58 time(s))
  • Attachment: Capture.JPG
    (Size: 32.77KB, Downloaded 48 time(s))
  • Attachment: 1.JPG
    (Size: 45.93KB, Downloaded 37 time(s))
  • Attachment: 2.JPG
    (Size: 44.30KB, Downloaded 37 time(s))
Read Message
Read Message
Read Message
Read Message
Previous Topic:object rotation/orientation question
Next Topic:Advice: Material/finish for car badge
Goto Forum:
   Go
Current Time: Thu May 23 08:14:22 UTC 2013
