Home » Support » 3D Applications » 3D Max - inverted normals
3D Max - inverted normals [message #3716] Thu, 02 April 2009 17:42 UTC Go to previous message
avatar ANIMEMI  is currently offline ANIMEMI
Hi I have been trying to make an old model printable. Arrg!
My test piece uploaded easily enough. But two trys and no Joy. INVERTED NORMALS!
Q: Can rogue geometry inside the Mesh (free floating faces ect) cause a Normals problem, Or will it pick up as a Non Manifold error first.
In Max there is a normal edit modifier but it will not work Globally if you have an Editable Mesh as your object.
So is Blender an option.
Can I turn my mesh into something else export it and re-import it.
Sifting through every poly just is not an option.
Thanks to anyone who can point me to a solution.
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:STL file from AutoCAD
Next Topic:3DS Max and unit conversion
Goto Forum:
   Go
Current Time: Wed Jun 19 12:19:39 UTC 2013
