Home » Community » Shapeways API » Submit model -
Submit model - [message #25464] Wed, 30 March 2011 20:48 UTC Go to previous message
avatar sebtest  is currently offline sebtest
Hi
I'm trying to discuss with shapeways.com server to upload a zip file.
Here are the exchanges between my program and the server.
What I dont understand is why the server answers with a new session_id when I invoked the submit_model API.
Thank you for your help
seb
here are the exchanges:
POST /modules/shapeways_api/webservice/v1/soap.php HTTP/1.1
Host: localhost
Content-Type: application/soap-xml; charset="utf-8"
Content-Length: 568
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ns1="urn:SW.wsdl" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Body>
<ns1:login>
<username xsi:type="xsd:string">sebtest</username>
<password xsi:type="xsd:string">my_real_password_was_there</password >
<application_id xsi:type="xsd:string">Test</application_id>
</ns1:login>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
HTTP/1.1 200 OK
Date: Wed, 30 Mar 2011 20:38:51 GMT
Server: Apache/2.0.52 (Red Hat)
X-Powered-By: PHP/5.2.13
Set-Cookie: iep=tgg0d4d802mk44tbgsk3fal824; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Content-Length: 532
Vary: Accept-Encoding
Content-Type: text/xml; charset=utf-8
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="urn:SW.wsdl" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><ns1:loginResponse><loginReturn xsi:type="xsd:string">tgg0d4d802mk44tbgsk3fal824</loginReturn ></ns1:loginResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
session identifer found = tgg0d4d802mk44tbgsk3fal824
Host: localhost
Content-Length: 1542
<SOAP-ENV:Body>
<ns1:submitModel>
<session_id xsi:type="xsd:string">tgg0d4d802mk44tbgsk3fal824</session_id >
<model xsi:type="ns1:SWModel">
<desc xsi:type="xsd:string">Test</desc>
<file xsi:type="xsd:base64Binary"> VUVzREJCUUFDQUFJQU9LcGZqNEFBQUFBQUFBQUFBQUFBQUFIQUJBQWMyVmlM bmR5YkZWWURBQ29nWk5OT0lHVFRmVUJGQUJ0amtzTGdrQVVoZGZlWDNHZ2Jj V29CVzBqRWdMYkpMaUpGdUpNSlpRak5rRVIvdmZtSlFiR3dHWE9kKzdqVFBM RFBrVWV6Um1lNnJ3aXlxNUZJK2hEd0VYSXUxRHRHN3VhaTVmZ1NWR0tUQ2p0 R0JkNHlGdkZrYXpUYkVzV2xGSzJIQnRUcTdwUXdrTFhDelN5cWhXT1hnV21N UE9tTlB6bkxCeWtGdjlJTDczTmxxNTZmTEw3dTU4OE5yeS9HN2pqZWxlSUNE Rm1JVVo4TWFLbWQwek4vSmpHZW9lalBUR0pPdXJvQzFCTEJ3aFFGMzBkclFB QUFHa0JBQUJRU3dFQ0ZRTVVBQWdBQ0FEaXFYNCtVQmQ5SGEwQUFBQnBBUUFB QndBTUFBQUFBQUFBQUFCQXBJRUFBQUFBYzJWaUxuZHliRlZZQ0FDb2daTk5P SUdUVFZCTEJRWUFBQUFBQVFBQkFFRUFBQUR5QUFBQUFBQT0= </file>
<filename xsi:type="xsd:string">out.zip</filename>
<title xsi:type="xsd:string">Test</title>
<view_state xsi:type="xsd:string">1</view_state>
<tags xsi:type="xsd:string">Test</tags>
<has_color xsi:type="xsd:boolean">1</has_color>
<modeltype xsi:type="xsd:string">ZIP</modeltype>
</model>
</ns1:submitModel>
</SOAP-ENV:Body>
HTTP/1.1 200 OK
Date: Wed, 30 Mar 2011 20:38:52 GMT
Set-Cookie: iep=197umsugmieutsuc96481i29l4; path=/
Pragma: no-cache
Content-Length: 532
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="urn:SW.wsdl" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><ns1:loginResponse><loginReturn xsi:type="xsd:string">197umsugmieutsuc96481i29l4</loginReturn ></ns1:loginResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:Materials list
Next Topic:email notification
Goto Forum:
   Go
Current Time: Wed May 22 20:21:35 UTC 2013
