Does the Processing for WSF remove material?
Does the Processing for WSF remove material? [message #24494] Sun, 06 March 2011 03:59 UTC Go to previous message
I know part of the processing for WSF involves sandblasting. Does this result in a certain amount of material being removed?
I ask as I've just received some models in which I used a small section - 0.95x0.70 mm Now my previous tests suggested this would be strong enough to support what I wanted, but when the model was received it was a little too flexible.
On checking I found the section was considerably smaller then what I had designed - by about 0.10-0.25 mm which is quite a bit on such a small section
So is some material lost? do I need to make an allowance for ti in my designed?
[Updated on: Sun, 06 March 2011 04:40 UTC]
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:facets in stl
Next Topic:Best Keychain material
Goto Forum:
   Go
