manifold, normals, strange texture
manifold, normals, strange texture [message #6198] Mon, 31 August 2009 21:20 UTC Go to previous message
avatar fourdee  is currently offline fourdee
I'm having a bunch of trouble with my models... I'm using Cheetah3D.
Here is my process:
- Create type in Illustrator
- Convert to shape
- Put holes at top
- Make compound path to punch holes
- Save as SVG
- Import SVG into Cheetah
- Put SVG path into extrude object
- Save as STL
When I import "fourdee.stl" into Shapeways, it works, but the image and 3d view shows strange lines across the front, but in Cheetah, it's perfectly flat.
See model 49069
When I import "fourdee-linear.stl" into Shapeways, it tells me only manifold objects can be printed. This is the same as the previous object, except I changed the bevel to linear.
See model 49070
When I import "helvetica2.stl" into Shapeways, it tells me the object has inverted normals.
I've been messing with all of this for a few days now, so I've lost track of everything I've done trying to get things to work...
  • Attachment: fourdee.zip
    (Size: 1.26MB, Downloaded 213 time(s))
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:non-manifold error checking?
Next Topic:Whole object is non-manifold, 20.3MB stl file
Goto Forum:
   Go
