Home » Support » 3D Applications » What export type to use in Maya 2013?
What export type to use in Maya 2013? [message #54409] Sun, 23 September 2012 02:49 UTC Go to previous message
avatar jrb1  is currently offline jrb1
So I have my model in Maya 2013 which has an export file type option called STL_DCE which says it's a STL exporter. Is this the right thing to use from Maya 2013?
Another possibility seems to be .obj which has the following export check boxes;
Groups
Point Groups
Materials
Smoothing
Normals
If .obj is the way to go should those be checked/unchecked?
- James
Read Message
Read Message
Previous Topic:Rhino Users - Naked Edges
Next Topic:Can you bend the rules for a Steel Pipe?
Goto Forum:
   Go
Current Time: Fri May 24 12:11:24 UTC 2013
