Get Free Shipping on all orders this Saturday and Sunday. · details
Home » Support » 3D Applications » Size,Dimension,Measurement.. of a mesh in X3D format
Size,Dimension,Measurement.. of a mesh in X3D format [message #55385] Mon, 15 October 2012 14:23 UTC Go to next message
avatar hbzoltan  is currently offline hbzoltan
Hi there!
I'm trying to get the right size of my model(mesh) in X3D. I've been trying to export my model with 3DMAX,MashLab,Blender. My original model in obj format created in Zbrush. I tried .wrl format used the Zbrush 3Dprint exporter tool but it messed up my UVtexture. 3DMAX can not export X3D and I can not see the measurements in MashLab.
The weird thing is that when I create a box in Blender and export and upload it inX3D forma to shapeways I get the correct dimensions. When I do exactly the same to my model I get wrong dimensions however the picture and the 3D of my model looks ok.
I don't know what the problem is with my model or the .
Does anyone have the same issue?
Is there any application that can show the exact measurement of my shape except Blender and can handle texture(UV) coordinates?
Re: Size,Dimension,Measurement.. of a mesh in X3D format [message #55393 is a reply to message #55385 ] Mon, 15 October 2012 18:16 UTC Go to previous messageGo to next message
If you are going to use a uv mapped object to apply a image/color on Full Colored Sandstone, it has to be in VMRL format. Oddly when you upload the model, SW recognizes each basic unit length as 1 meter!! So if your model is 10 x 10 x 10, the printer will try to print a model 10m x 10m x 10m. Which it can't do, so it gets scaled to a size that will print, so wrong dimensions.
Post a ink to the file, its easier to diagnose a problem.
Use Meshlab to convert your file to VMRL .If the UV mapping is looks ok in Meshlab, it will export to SW if the model has a proper mesh.
In Meshlab if you want to see the bounding box dimensions use this Filters/Quality measure and computations/compute geographic measurements
If you want to scale the object use this, Filters/Normals/Curvature/Orientation>Transform scale. A slight problem can occur with uploading . Scroll down on the link provided below to see what changes are needed. Makes sense actually since only access to the UV texture is in the zipped file you upload. chup_and_meshlab
The .x3D format after tests proved to be a better format to export with if you have several different materials plus a uv texture on your model. The wrl only seems to support 1 material and a texture. With .x3D much more options for a colored model
[Updated on: Fri, 19 October 2012 15:28 UTC]
Re: Size,Dimension,Measurement.. of a mesh in X3D format [message #55710 is a reply to message #55393 ] Sat, 20 October 2012 16:57 UTC Go to previous message
If you scaled it in blender you might have to apply scale (Ctrl + A). Hope this helps.
Previous Topic:Which Application to Use?
Next Topic:Can two separate objects be printed?
