Home » Community » Work in progress » Animatronic Owl Project
 () 2 Vote(s)
Animatronic Owl Project [message #51114] Tue, 10 July 2012 15:58 UTC Go to next message
avatar InnerbreedFX  is currently offline InnerbreedFX
My name is Jonny,
Iv' been an undiscovered artist for many years.
most of my personal work involves character designs and concept games art, but i have a real passion for animatronics and robotics of which i have followed for many years.
cut the story short...
http://www.innerbreed.co.uk/
My project has been running for a while. The first few prototypes were all hand sculpted and cast in house in molds. but thanks to Shapeways 'i have a real opportunity to make this project take off.
This is an old image of some of the parts and so improvements have been made since.
index.php?t=getfile&id=18363&private=0
The final bird will be feathered professionally by the UK's leading taxidermist, Mike Gadd.
Further reading.....
ABOUT THE PROJECT
A brief description about the project...
A lot of research with raptors require to capture individuals to put on identifying leg bands, and may radio transmitters. Raptors can be very difficult to trap. One of the most efficient tools is to find an active nest. The adults raptors will usually be protective of their nestlings, and especially aggressive toward large birds, such as the hawk or owl. They use this behavior to facilitate capturing other hawks. Essentially, they will set up a net near the nest and place a lure in front of it. The hawks will swoop at the lure to try to chase it from the nest area and get captured in the net. It is a very effective trapping method, but there are several problems that a good animatronic lure would overcome.
The goal in building this project?...
Some researcher have made stuffed lure with heads that can be rotated with radio control. They do not work well, but I believe my animatronic hawk, would be a substantial leap in terms of trapping lures. The cocking of the head, opening of the beak, and for the future development i will make it spread its wings, then it would make it, I suspect, incredibly efficient in trapping raptors. I am certain that, if it was confirmed to work well, numerous researchers would be interested in forgoing the headaches of live lures and stuffed decoys by getting an animatronic. My goal is to successfully field test this idea.
How this project aims to solve problems...
There are several problems that a good animatronic lure would overcome. First, we have to have federal and state permits to use a live lure for this purpose. The lures are usually non-releasable rehabilitated birds with some injury (e.g., broken wing). Getting these permits is a very onerous task due to federal and state legal requirements. Second, because the lure is alive, we have to provide food and care for it, and protect it from environmental conditions such as cold, heat, direct sunlight, etc. Third, Animal Welfare Legislation in the United States (which is even more restrictive in the UK) has led to many institutions not allowing the use of a live lures for this purpose without substantial justification and oversight. This has led many researchers to use plastic scarecrow lures. However, these do not work well for trapping.
Working With Nature...
Life-like movements are critical for getting an aggressive response from hawks. I know the current hawk has a long way to go but as far as im aware there is nothing like this currently out there? The use of scarecrows or stuffed owls also may induce greater disturbance to the nesting hawks due to low aggression response but repeated disturbance due to the researcher trying to capture them repeatedly. This is also problematic when trapping in remote locations; you want the trap to work the first time after hauling all the equipment in to the site.
[Updated on: Tue, 10 July 2012 16:10 UTC]
Innerbreed.co.uk
Create - Innovate - Inspire
Re: Animatronic Owl Project [message #51115 is a reply to message #51114 ] Tue, 10 July 2012 16:00 UTC Go to previous messageGo to next message
index.php?t=getfile&id=18364&private=0
Innerbreed.co.uk
Re: Animatronic Owl Project [message #51799 is a reply to message #51115 ] Tue, 24 July 2012 21:27 UTC Go to previous messageGo to next message
I cannot thank Shapeways enough...
index.php?t=getfile&id=18866&private=0
  • Attachment: Untitled.png
    (Size: 251.95KB, Downloaded 915 time(s))
Innerbreed.co.uk
Re: Animatronic Owl Project [message #52596 is a reply to message #51114 ] Tue, 14 August 2012 22:26 UTC Go to previous messageGo to next message
index.php?t=getfile&id=19616&private=0
  • Attachment: iso.jpg
    (Size: 167.11KB, Downloaded 815 time(s))
[Updated on: Tue, 14 August 2012 22:27 UTC]
Innerbreed.co.uk
Re: Animatronic Owl Project [message #52597 is a reply to message #51114 ] Tue, 14 August 2012 22:27 UTC Go to previous messageGo to next message
index.php?t=getfile&id=19617&private=0
Innerbreed.co.uk
Re: Animatronic Owl Project [message #52607 is a reply to message #52597 ] Wed, 15 August 2012 09:17 UTC Go to previous messageGo to next message
avatar icarus3d  is currently offline icarus3d
Very interesting work. i hope we will see a clip when the owl get alive Smile
Re: Animatronic Owl Project [message #52637 is a reply to message #52607 ] Wed, 15 August 2012 16:25 UTC Go to previous messageGo to next message
hi, thanks for posting.
yes i hope to include a few videos while once its all rigged up to the controls.
post development videos (in its skeleton form) and also once its been feathered. Cool
i have a few concerns about the amount of space inside for the cables that activate the wings but ill get around this..
Innerbreed.co.uk
Re: Animatronic Owl Project [message #52719 is a reply to message #51114 ] Thu, 16 August 2012 16:00 UTC Go to previous messageGo to next message
index.php?t=getfile&id=19676&private=0
Innerbreed.co.uk
Re: Animatronic Owl Project [message #52751 is a reply to message #52719 ] Fri, 17 August 2012 11:41 UTC Go to previous messageGo to next message
avatar Eeppium  is currently offline Eeppium
Cool project!
keep us posted on those videos =)
Re: Animatronic Owl Project [message #53888 is a reply to message #52751 ] Tue, 11 September 2012 17:38 UTC Go to previous messageGo to next message
some images from the latest assembly.
http://i531.photobucket.com/albums/dd355/innerbreed/2012-09-05152045.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-09-05152314.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-09-05152234.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-09-05152144.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/underside-1.jpg
Electrical housing designed by a friend of mine @
http://www.shapeways.com/shops/DiaLFonZo-Copter
http://i531.photobucket.com/albums/dd355/innerbreed/servocaseside.png
http://i531.photobucket.com/albums/dd355/innerbreed/Innerbreed-Bird-Assembly-10-09-2012.jpg
Innerbreed.co.uk
Re: Animatronic Owl Project [message #54398 is a reply to message #51114 ] Sat, 22 September 2012 18:10 UTC Go to previous messageGo to next message
http://i531.photobucket.com/albums/dd355/innerbreed/SAM_0672_zps7d6a7ff3.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/SAM_0673_zpsb7a626eb.jpghttp://i531.photobucket.com/albums/dd355/innerbreed/SAM_0669_zps59cf66eb.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/SAM_0674_zps61397e97.jpg
Innerbreed.co.uk
Re: Animatronic Owl Project [message #54399 is a reply to message #54398 ] Sat, 22 September 2012 18:16 UTC Go to previous messageGo to next message
Great progress! =)
keep ´em coming.
Re: Animatronic Owl Project [message #54445 is a reply to message #54398 ] Mon, 24 September 2012 14:29 UTC Go to previous messageGo to next message
And a Test video:
http://www.youtube.com/watch?v=RO-f7aXktyg&feature=plcp
Innerbreed.co.uk
Re: Animatronic Owl Project [message #54461 is a reply to message #54445 ] Mon, 24 September 2012 19:57 UTC Go to previous messageGo to next message
Very nice!
quite smooth movements, very birdlike thing going on with the head looking around.
are you going to give him the feathery outfit soon ?
Re: Animatronic Owl Project [message #54498 is a reply to message #54461 ] Wed, 26 September 2012 08:56 UTC Go to previous messageGo to next message
yes it will soon be feathered. one the programming has been done.
here is a better video:
http://www.youtube.com/watch?v=BVPcXjKRJ6I
Innerbreed.co.uk
Re: Animatronic Owl Project [message #55381 is a reply to message #51114 ] Mon, 15 October 2012 13:34 UTC Go to previous messageGo to next message
The mech:
http://i531.photobucket.com/albums/dd355/innerbreed/2012-10-15104404.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-10-15104507.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-10-15104531.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-10-15104545.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-10-15122700.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-10-15122725.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/2012-10-15130246.jpg
Innerbreed.co.uk
Re: Animatronic Owl Project [message #57497 is a reply to message #51114 ] Mon, 26 November 2012 16:24 UTC Go to previous messageGo to next message
http://i531.photobucket.com/albums/dd355/innerbreed/afterfocus_1352473188239.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/Untitled-2.jpg
Innerbreed.co.uk
Re: Animatronic Owl Project [message #57503 is a reply to message #57497 ] Mon, 26 November 2012 18:21 UTC Go to previous messageGo to next message
avatar Mitchell Jetten  is currently offline Mitchell Jetten
Damn that's a cool ambitious project you are working on!
keep the pictures coming!
Kind regards,
Mitchell Jetten
Customer Service Agent
Shapeways
Re: Animatronic Owl Project [message #57547 is a reply to message #57503 ] Tue, 27 November 2012 14:44 UTC Go to previous messageGo to next message
avatar BITGEM  is currently offline BITGEM
Amazing project! This is very interesting and an incredible amount of work. I hope you can take it all the way to completion!
[Updated on: Tue, 27 November 2012 14:44 UTC]
www.bitgem3d.com
Re: Animatronic Owl Project [message #57589 is a reply to message #57547 ] Wed, 28 November 2012 07:44 UTC Go to previous messageGo to next message
avatar AD-Edge  is currently offline AD-Edge
Will be keeping an eye on this, very impressive work.
Looking forward to seeing it with feathers and final details, thats for sure Cool
Re: Animatronic Owl Project [message #57598 is a reply to message #57589 ] Wed, 28 November 2012 12:22 UTC Go to previous messageGo to next message
Woahhh - love it!
Did I spot Blender there? Wink
Re: Animatronic Owl Project [message #58509 is a reply to message #51114 ] Wed, 12 December 2012 21:02 UTC Go to previous messageGo to next message
Thank you all for your comments. I will be talking to my taxidermist early January regarding the feathering. i have made up two models (one is RC controlled and the other is autonomous) and i hope to get them both feathered.
@ bartv,
yes i have used blender to sculpt the head over the eye control mech so it fits perfectly. Wink
Just waiting for one tiny part from shapeways (Target ship date was today?) till i finish the second (RC) model.
Errm.. images, yes... just the new control case..
http://i531.photobucket.com/albums/dd355/innerbreed/SAM_0767.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/SAM_0766.jpg
http://i531.photobucket.com/albums/dd355/innerbreed/SAM_0764.jpg
Innerbreed.co.uk
Re: Animatronic Owl Project [message #60433 is a reply to message #58509 ] Sat, 19 January 2013 20:23 UTC Go to previous message
Ok a date as been set for the next stage. We will begin in feathering process from 18th February.
This is great news for the project and im really looking forward to it.
index.php?t=getfile&id=25828&private=0
Innerbreed.co.uk
Previous Topic:My first 3D Print Model: Lumia Wireless Charger holder
Next Topic:Doctor Who Sonic Screwdrivers
