Home » Community » General Discussion » White Detail Surface oxidation
White Detail Surface oxidation [message #42696] Wed, 25 January 2012 06:52 UTC Go to previous message
avatar masked  is currently offline masked
So my WD model arrived about 10 hours ago--first time that I've tried this material. The surface of the model was smooth, slightly waxy, and had an apparent light shine under light. Within the time frame in which I've had it out of its delivery bag, the surface has been exposed to a slightly moist environment of ~25 degrees C under a compact fluorescent bulb, and has developed a "gritty" surface that has the texture of sandstone over the exposed surface. The underside of the surface exposed (visible internal details) has been unchanged. The model also has a distinct odor whereas one was not noticeable before.
Does anyone know the chemical process that this is undergoing?
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:create 3D Models in realtime using MS-Kinect + fast graphic-card
Next Topic:"Special" listings for designs
Goto Forum:
   Go
Current Time: Wed Jun 19 10:35:27 UTC 2013
