Home » Support » Buying » Volume (price) calculations don't appear trustworthy
icon5.gif  Volume (price) calculations don't appear trustworthy [message #1866] Mon, 03 November 2008 10:21 UTC Go to previous message
avatar Xcapee  is currently offline Xcapee
Ok - I have to say that the pricing policy is great - only paying for volume printed. It's just that I don't trust the volume calculations.
I have uploaded a design stage by stage, and the price (volume) calculations don't make any sense.
All prices quoted are in WSF
The first part, an empty tube with 1mm thick walls, ID = 35mm, OD = 37mm and height 23mm costs $4.86 which equates to 2.6 cm^3. This is the correct volume.
Cylinder model
/modules/udesign/utils/openfile.php?id=8122&f=8122_small.jpg
Add a ring of warped text to the top of it, thickness = 1mm, height = 7mm. If it weren't text, but a solid cylinder it would have a volume of 0.8 cm^3. Since it is text, it should be a lot less than that. However the price for my original cylinder plus text ring is now $10.17, or a total of 5.4 cm^3, more than double the volume and cost of the plain cylinder alone.
Cylinder plus text ring
/modules/udesign/utils/openfile.php?id=8112&f=8112_small.jpg
Something funky is going on with the text volume calculation.
It gets worse.
If I add a ring of text around the original cylinder (not on top of it) so that the effect is embossed text raised 0.5mm, that should add much less than 0.4 cm^3 but it adds another 2.8 cm^3 or 2.9 cm^3 (I have two such embossed text rings).
So my final model is being priced at $20.91 when the price should be well less than $10. Probably less than $7.00.
/modules/udesign/utils/openfile.php?id=8120&f=8120_small.jpg
It doesn't really give me much confidence in the pricing for more complex models.
Would anyone care to explain what's going on?
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:Customer Service Unreliable?
Next Topic:Error when selecting shipping address different to billing address
Goto Forum:
   Go
Current Time: Tue May 21 14:38:24 UTC 2013
