Yet two other D16s
Yet two other D16s [message #55781] Mon, 22 October 2012 21:53 UTC Go to previous message
Shapeways Crew
Hi there,
In my attemps to make a D16, I found a D16 with a tetrahedral symmetry. Basically, take a tetrahedron (triangular pyramid), put it inside a sphere and then replace each vertex by a group of 3 circular faces, and keep one circular face where the tetrahedon had its own faces (3x4 + 4 = 16).
Another way to construct is is to take a truncated tetrahedron (4 triangular faces and 4 hexagonal faces) and then put a face for each vertex but also at the center of each hexagons.
But as you can see the faces that are at the center of the hexagons do not touch the other faces. They are what AleaKybos call "rattlers". In order to maximize the radius of the faces, you can turn a little bit each group of 3 faces corresponding to one triangle of the truncated tetrahedron, say, counter-clockwise. In this way you get some extra space to make all the faces grow a little bit. Repeat the process until you touch the (former) rattler. It is a similar operation that allows to go from the D24 to the snub-D24. That why I call this new D16 the snub-D16 with Tetrahedral symmetry.
In this image I colored the different groups of faces to better understand the process (the one nearly grey is actually orange, and the one nearly black is actualy blue, sorry for the poor rendering).
index.php?t=getfile&id=22013&private=0
The gain on the separation (that is the angle at its vertex of the cone that goes from the center of the sphere to one circular face) seems low, but actually this is a big improvement: we go from 50.48° to 51.92°
Note that none of these dice would have number on their face, so they cannot compete for the D16 Contest...
[Updated on: Tue, 23 October 2012 11:53 UTC]
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:Quadrifolium
Next Topic:A Voronoi Halloween
Goto Forum:
   Go
