Home » Community » It arrived! » Futtminx by OSKAR
Futtminx by OSKAR [message #25840] Sat, 09 April 2011 09:51 UTC
Hi Shapeways fans,
Futtminx is a tribute to the brilliant Tuttminx design by Lee Tutt, which has been mass produced by Leslie Lee / VeryPuzzle. The hexagonal faces of the original Tuttminx can only be turned by multiples of 120 degrees. If one tries to makes 60-degrees turns with the Tuttminx, then adjacent turns are blocked. It is not possible to fully unbandage Tuttminx into a doctrinaire puzzle, as Tuttminx is arguably a puzzle that jumbles.
"Futtminx" stands for "Fudged Tuttminx". The corners are fudged into threefold symmetry, where all edges are fudged and made identical. The puzzle has a lot of gaps between the pieces as a result of the fudging. Also, the pieces shift a bit during a turn to make all turns possible, including 60-degrees hexagon turns.
One innovation of this puzzle is that 31 of the centers are bolted from the inside out. This saves a lot of work for placing caps on the centers and it looks better. The 32nd center has a long bolt that bolts the two core hemispheres together.
Watch the YouTube video.
Buy the puzzle at my Shapeways Shop.
Read more at the Twisty Puzzles Forum.
Check out the photos below.
Enjoy!
Oskar
index.php?t=getfile&id=8130&private=0
index.php?t=getfile&id=8131&private=0
index.php?t=getfile&id=8132&private=0
index.php?t=getfile&id=8133&private=0
Previous Topic:Spiky Club
Next Topic:Square Fabric
