with SS the minimum wall thickness is 3mm, does this mean that you cannot have an object that is 1mm*3mm*10mm? And that the smallest dimension is 3mm no matter what the other dimensions are? or can you have a 1mm by 1mm * 10mm object?
Or does a ring band has to be 3mm thick in both dimensions?
