The sort criteria is not longer available in the URL (?sort=newest)
It seems to be available in the shop page. Has the shop page also changed because currently the layout is 2 items per line.
It seems also that the newest on the shop page doesn't work as before (I have updated an item some minutes ago but it is not visible as first item) =>
seems to work now.
The page is lost when deleting an item (also that no delete button is availabe on item edit level is uncomfortable. Because normally I do deleting on informations available here)
Oncemore moveing around in a shop having more then 3 pages is a mess and hasn't changed with this update ....
Also the filter seems to be lost when moving around ...
(Setting a filter. Edit one element. Then the only? chance is to select back via browser?, which ends up in an unfiltered list.
PLEASE, PLEASE add some enhanced moving around functionality
(I would expect a next/back button on item level which stays inside the filter choice. The next did exist in some earlier versions but only moving around in the default view)
