| Rhino simple bullet with manifold problems [message #8655] Wed, 30 December 2009 22:42 UTC |
Hi, I'm new here I just started with something simple. I made a bullet using the revolve technique. When I export to STL, I'm not exactly sure of the settings but for the simple settings I made it 0.01mm. From what I can see, some of the errors look pretty bad, especially near the tip. Is there an easy way to fix it, or should I start the whole thing over using some other methods?
Attachment: 9mm.stl
(Size: 796.71KB, Downloaded 99 time(s))
| Re: Rhino simple bullet with manifold problems [message #8657 is a reply to message #8655 ] Thu, 31 December 2009 03:57 UTC |
I suggest you "Netfabb studio basic" (free), load your model then perform the automatic repair. It is simple and fast. Here your model fixed. I have to flip the triangles as the analysis tell me that the shell has negative volume (will be rejected). I made an upload test and the model now is ok. Select "mm" as you upload the file.
Umberto
[Updated on: Thu, 31 December 2009 03:57 UTC]
| Re: Rhino simple bullet with manifold problems [message #8660 is a reply to message #8657 ] Thu, 31 December 2009 08:11 UTC |
Hi Umberto, thanks for the info, I tried netfabb and it worked great for everything. I thought that Rhino was used by jewelry designers for 3D printing, so I don't get why it wouldn't work out of the box. Can't wait to see how it turns out!
