A watch for musicians !
A watch for musicians ! [message #66091] Sat, 13 April 2013 15:18 UTC Go to next message
avatar jeremypatrickdahan  is currently offline jeremypatrickdahan
Hi everyone,
I have create a watch that does not tell the time, but the musical scales.
The idea is simple : if you place the chromatic scale on a circle, the other scales are just a series of tone or half-tone.
For the major scale : Tone, tone, half-tone, tone, tone, tone, half-tone. We just need to make a figure that represents those intervals, figure that won't vary.
To get all the scales, we just have to rotate the figure, or the chromatic scale, and the figure will indicate the appropriate notes, for each fondamental.
https://www.dropbox.com/s/mteuj97bx3ub8lt/GammesCompl%C3%A8t es.pdf
I made a watch on AutoCAD, but Shapeways won't print it until it's strong enough to be printed. Ok, but it's my first 3D printing project, and I want to make the lightest watch possible and I don't know how to do. I tried all the materials, and I increased the thickness of a lot of elements, but maybe an expert in 3D modeling who wants to have a cool watch could give me hand...
Please !
JD
PS : the notes notation is the French one, but I will make an English notation version
  • Attachment: M5.stl
    (Size: 3.22MB, Downloaded 49 time(s))
Re: A watch for musicians ! [message #66096 is a reply to message #66091 ] Sun, 14 April 2013 06:00 UTC Go to previous messageGo to next message
Nice design! Surprised
All of the notations need to be completely redone or perhaps push pulled because the letters and numbers are too thin. Also, a lot of the details on top of the main body are not connected to the main body. They are hovering just above it. So you need to either boolean those details to the main body or make them much thicker.
What material did you want to make this is in?
Each material has a webpage covering all of the design criteria you need to know to have a successful design. For example this page covers the design rules for Shapeways' Strong & Flexible material.
Patterns For CNC
Re: A watch for musicians ! [message #66117 is a reply to message #66096 ] Sun, 14 April 2013 16:41 UTC Go to previous messageGo to next message
I initially wanted to make it in stainless steel, but it needs to be very thick, so quite heavy.
Polished alumide seems good for the watch, don't you think ?
For the circle hovering on the top of the watch, it was made on purpose : the element is locked by the small round blocks but can be removed to place another one. But I know the system is likely to break, I just don't know what to do...
Thanks !
PS : Here's the DMG file :
ACAD 2013
https://www.dropbox.com/s/xrqvp3wuxad9dlp/M5.dwg
ACAD 2010
https://www.dropbox.com/s/88jm6pqh2i6fnbh/M5-2010.dwg
Re: A watch for musicians ! [message #66125 is a reply to message #66117 ] Sun, 14 April 2013 20:01 UTC Go to previous messageGo to next message
It's not a matter of it breaking, the problem is none of Shapeways printers can print most of the components and embossings because of thin walls. If you tried to print that you'd end up with specks of dust for some of the parts. Just thicken everything up and it'll be fine. Smile
Patterns For CNC
Re: A watch for musicians ! [message #66261 is a reply to message #66125 ] Wed, 17 April 2013 13:51 UTC Go to previous messageGo to next message
All right, thanks for your advice, here's the new version :
STL : https://www.dropbox.com/s/b4ni106adt8otg3/M7.7.stl
DWG : https://www.dropbox.com/s/17axyay2dwmp6dq/M7.7.dwg
Render in PDF : https://www.dropbox.com/s/absbpbz1y8z6dsb/M7.7.pdf
I think this one is thick enough and will work.
The project is under MIT License, so feel free to try to improve it, and give me feedback !
I will upload pictures when it's printed.
Thanks for your help !
Re: A watch for musicians ! [message #66286 is a reply to message #66261 ] Wed, 17 April 2013 19:11 UTC Go to previous messageGo to next message
Looks good. It needed repairing in Netfabb.
Before you upload it. Why did you not use the commands I told you about? (facetres = 10)
It will give you a smoother model.
I like the idea of using your own strap on the back. I would use two of these for comfort, maybe on the edges like a real watch.
It uploaded OK. Whether it is printable? You will just have to order it to find out.
If it fails it will be the letters. It might be worth considering the letters being engraved into the surface
[Updated on: Wed, 17 April 2013 19:17 UTC]
Re: A watch for musicians ! [message #66287 is a reply to message #66286 ] Wed, 17 April 2013 19:36 UTC Go to previous message
I tried the commands, isolines is quite handful, but I could not see the effect of facetres.
I suppose it makes the surface smoother on the exported stl, but super curve detail is not a priority for now, but thank you.
Actually I wanted to try with only one strap on the back, just to try.
I discovered one of my friends had a 3D printer, so I will print a prototype before making more changes, and order it with Shapeways, in Alumide.
I uploaded your file too : http://www.shapeways.com/model/1046086
Sorry, I forgot the 2010 version again : https://www.dropbox.com/s/oacf412kyw8wbjj/M7.7-2010.dwg
Thanks a lot Jacant !
Previous Topic:New Guy - A Few Pointers Needed
Next Topic:I loathe Rejection.
