Home » Support » 3D Printing » Intersecting
Intersecting [message #582] Mon, 04 August 2008 17:48 UTC Go to next message
avatar kingcoma  is currently offline kingcoma
Hi everyone,
so I'm currently working on two simple characters I would like to print.
However, I'm not sure if it may intersect with each other.
I've attached a screenshot of the parts that are intersecting. (2)
Also, for the head I have 2 spheres and another form which are seperatly modelled, and are also intersecting with the 'base' mesh. Is this a problem? Or does the printer see everything as one mesh? (1)
index.php?t=getfile&id=37&private=0
[Updated on: Mon, 04 August 2008 17:50 UTC]
Re: Intersecting [message #625 is a reply to message #582 ] Tue, 05 August 2008 15:47 UTC Go to previous messageGo to next message
avatar Owensar  is currently offline Owensar
I could be wrong but most 3D printers take the whole mesh, and then build it up like an Mrsi scanner does. Doing layer by layer. So having 2 intersecting parts should mean they just fuse on the model.
Re: Intersecting [message #631 is a reply to message #582 ] Tue, 05 August 2008 16:38 UTC Go to previous messageGo to next message
King,
What could be an issue is that the model is not manifold.
http://www.shapeways.com/tutorials/thinks-to-keep-in-mind
What tool are you using? At the url above you can see how to check if a model is manifold in Blender.
Re: Intersecting [message #636 is a reply to message #631 ] Tue, 05 August 2008 18:38 UTC Go to previous message
Hey, Thanks for the replies! Surprised
I use cinema4d for modelling, and exported it as an .STL file.
I also downloaded a trial version of accutrans, where I could check if it's water-tight.
If there are edges shared by one ore more faces, it will tell you this.
So I checked it, and it said it was water tight, so I gues it would be ok.
I think I'll be uploading soon, however I'm not sure about the size. Have to check the forum a little bit to get some more advice.
Previous Topic:Interlocking Rings
Next Topic:threads
