| FOC Onslaught Upgrade Kit [message #58397] Tue, 11 December 2012 14:29 UTC |
| Re: FOC Onslaught Upgrade Kit [message #58399 is a reply to message #58397 ] Tue, 11 December 2012 14:38 UTC |
But, why is it called a Hinge Blaster? And why the two superfluous Hinges on Onslaught's legs?
In Vehicle Mode, Onslaught takes his new Hinge Blaster and turns it into a new attachment point for the green blaster!
The 5mm peg hole lets the green blaster attach to the back, right between the Hinges! No more stressed plastic, no more attaching to those two fiddly pages on his arms.
(And yes, other 5mm weapons can be attached as well)
FOC Onslaught Upgrade Kit on Shapeways
And in the spirit of Hinge Blasters everywhere, Onslaught finally doesn't aim downwards anymore! Unlike the original connection, which left the gun pointing at the ground, the new connection lets Onslaught aim up, up, up!
The Hinge rotates through 360 degrees itself, only blocked by the vehicle itself and the ground, so Onslaught can aim all the way back at cars behind him if he wants.
| Re: FOC Onslaught Upgrade Kit [message #58400 is a reply to message #58399 ] Tue, 11 December 2012 14:39 UTC |
When it comes to war, though, more weapons is always better! Arm Onslaught with his full complement of weapons and roll into battle!
Onslaught's Twin Cannons plug into the 5mm holes on the hinge pieces, above the Hinge Blaster. Other 5mm weapons can be attached here as well.
Hope you all like the FOC Onslaught Upgrade Kit.
As always, comments and criticisms are welcome and undoubtedly appreciated
