Home » Support » 3D Design » Creator fails to launch with Socket error on Ubuntu 9.04
Creator fails to launch with Socket error on Ubuntu 9.04 [message #4547] Fri, 22 May 2009 09:35 UTC Go to next message
avatar NotesSensei  is currently offline NotesSensei
On Ubuntu 9.04 with the latest Java it fails loading the app with a error
java.net.maleformedURLException unknown protocol:socket
Sad
Re: Creator fails to launch with Socket error on Ubuntu 9.04 [message #4602 is a reply to message #4547 ] Mon, 25 May 2009 09:02 UTC Go to previous messageGo to next message
Would you please be so kind to let us know what java version you are are using?
To my knowledge Sun java does work, however openjdk sometimes has problems indeed.
Thanks, kind regards, Arno
Re: Creator fails to launch with Socket error on Ubuntu 9.04 [message #4640 is a reply to message #4602 ] Wed, 27 May 2009 09:49 UTC Go to previous messageGo to next message
Java(TM) SE Runtime Environment (build 1.6.0_13-b03)
Java HotSpot(TM) Server VM (build 11.3-b02, mixed mode)
on Ubuntu 9.04
I suspect: I'm using the new plug-in that might be the issue. Also network latency is *way* higher from Asia than other locations.
Re: Creator fails to launch with Socket error on Ubuntu 9.04 [message #4642 is a reply to message #4640 ] Wed, 27 May 2009 12:11 UTC Go to previous message
Thanks for the followup. I have relayed the information to our developers. I hope to give you an update soon.
Sorry for the inconvenience
Previous Topic:slip fit
Next Topic:Downscale my design?
