| Re: Burlesque Dancer Figure "raw" and painted pics [message #42101 is a reply to message #42080 ] Tue, 17 January 2012 08:53 UTC |
I'm in love!
Awesome work...
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42115 is a reply to message #42080 ] Tue, 17 January 2012 14:10 UTC |
One word: "Awesomeness" !
http://www.3Dizingof.com
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42116 is a reply to message #42115 ] Tue, 17 January 2012 14:13 UTC |
That's one hot virtual vixen! Nice work on the model and the finish. Is she hollow or solid?
bobd
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42122 is a reply to message #42103 ] Tue, 17 January 2012 15:37 UTC |
Very nice modeling and stunning detailing
I am also trying to obtain a very smooth finish with WSFP or even WSF for larger parts on car models.
With car models, the paint has to be glossy. I use the same technique as you, with primer and sanding. I use Tamiya TS spray cans but I had some reactions with the material (small bubbles). Did you also experienced this? Or do you use water based paints?
Cheers.
Alain
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42135 is a reply to message #42080 ] Tue, 17 January 2012 17:34 UTC |
Looks great!
Nice finishing.
Kaetemi
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42180 is a reply to message #42135 ] Wed, 18 January 2012 09:35 UTC |
Congratulations great work.
V
www.dotsan.com
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42196 is a reply to message #42116 ] Wed, 18 January 2012 18:31 UTC |
She is hollow (no easy feat- especially on the arms!) the head, torso/arms, hips/legs, and seat base were all separate objects. I filled each piece with fine silica sand from the craft store and after tamping it down solid I capped off each opening with 5 min non-expanding epoxy. After each piece is fully painted I glued them all together with the same epoxy and it comes out feeling as heavy and solid as any Sideshow or Electric Tiki statue!
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42197 is a reply to message #42122 ] Wed, 18 January 2012 18:51 UTC |
Hi Alain, the primer I use is VHT automotive filler primer and I always let each coat cure for 14-16 hours before sanding. The only paint I use on figures is water based acrylic (usually Golden or Vallejo) I airbrushed the skin tones all over first, then did everything else with an assortment of sable brushes. Finished her off with several coats of Testor's Dullcote spray and a light "dusting" spray of clear gloss lacquer to give just a slight specular hit.
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42384 is a reply to message #42197 ] Fri, 20 January 2012 22:54 UTC |
Thank you very much, that will help. I will try with automotive filler.
Cant' wait to see your future work.
Alain.
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42446 is a reply to message #42080 ] Sat, 21 January 2012 17:13 UTC |
Wow, very impressive. I must try the filler primer with my first WSF model. Been trying to work out how to paint it, although mine are going to be rather smaller.
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42476 is a reply to message #42446 ] Sat, 21 January 2012 23:36 UTC |
If it is polished WSF the filler primer works better and requires fewer coats and less sanding. If the print is not polished, be ready for LOTS of sanding and extra filler coats to get totally smooth.
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42485 is a reply to message #42080 ] Sun, 22 January 2012 08:18 UTC |
lol, yeah good point, would rather it be finished before 2013. I'm in the UK so will have to try a different brand. Fingers crossed I can find one which works.
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42509 is a reply to message #42485 ] Sun, 22 January 2012 21:01 UTC |
Try Halfords.
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42511 is a reply to message #42509 ] Sun, 22 January 2012 21:24 UTC |
will do. Looks like there's some in stock in my local store.
| Re: Burlesque Dancer Figure "raw" and painted pics [message #42834 is a reply to message #42829 ] Fri, 27 January 2012 00:21 UTC |
Thanks Glenn! That means a lot coming from someone with such excellent prints of your own (love the Easter Island heads!)
I just got a commission request for another Burlesque Dancer with a custom paint job- on this one the client wants all the clothing including shoes to look like super shiny patent leather or pvc. I can't wait to get the print so I can start on it!
| Re: Burlesque Dancer Figure "raw" and painted pics [message #43988 is a reply to message #42834 ] Tue, 14 February 2012 08:01 UTC |
Amazing, this is probably the best finished 3d printed figurine I've ever seen. You can't tell it's 3d printed at all. What a talent!
www.studiogijs.nl
| Re: Burlesque Dancer Figure "raw" and painted pics [message #43991 is a reply to message #43988 ] Tue, 14 February 2012 09:21 UTC |
Thanks Gijs! That is very kind, it's amazing what a little airbrushing and LOTS of sanding can do
