Home » Support » 3D Applications » After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts.
After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40120] Mon, 12 December 2011 04:46 UTC Go to next message
avatar yoni.binstock  is currently offline yoni.binstock
Hi guys,
I'm new to 3d printing and I'm having a problem I can't get around.
I want to upload templates from open source sites and then manipulate in Google SketchUp.
Unfortunately, when ever it uploaded to SketchUp, I can't break it down into smaller parts.
Any suggestions?
yoni.binstock
Also as a side question, what's the best way to form curving cylinders?
Re: After uploading a file from thingiverse or sketchup, I can't manipulate the individual parts. [message #40136 is a reply to message #40120 ] Mon, 12 December 2011 14:48 UTC Go to previous messageGo to next message
Hi and Welcome.
Try Google Warehouse for Sketchup editable files http://sketchup.google.com/3dwarehouse/
Other sites will give you STL files which may be difficult to edit in SketchUp.
Good luck.
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40143 is a reply to message #40120 ] Mon, 12 December 2011 17:27 UTC Go to previous messageGo to next message
avatar denali3ddesign is currently online denali3ddesign
Hi yoni,
In addition to Duann's comment, keep in mind that if the original modeler didn't make the model using groups in Sketchup, you will have a very hard time editing the model. Its often easier to start over from scratch.
To form curving cylinders, you're probably going to need a plugin. Look at Curviloft, an advanced tool, or post a specific example of what you want to do and I'll help you.
-Marcus
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40193 is a reply to message #40120 ] Tue, 13 December 2011 18:47 UTC Go to previous messageGo to next message
You did "explode" the mesh you imported, right? You can edit, i'ts just very tedious without groups.
The Curviloft plug-in looks useful, but if you are just getting started you can get basic jobs done with the "follow me" tool. This is often called a Sweep in most other programs. You simply draw your path with lines and arcs, then draw your profile shape on the endpoint at a 90 degree angle. Rotate your view correctly and Sketchup will orient the shape properly. Click Tools>FollowMe and drag the shape along the line as shown here. If you are making several shapes you may want to draw the parts apart from each other and move them together later so the cursor does not snap to the wrong points.
index.php?t=getfile&id=12644&private=0
  • Attachment: follow.png
    (Size: 70.80KB, Downloaded 143 time(s))
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40206 is a reply to message #40193 ] Tue, 13 December 2011 23:47 UTC Go to previous messageGo to next message
Thanks a lot everyone. Your comments have been super helpful!
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40271 is a reply to message #40206 ] Wed, 14 December 2011 23:54 UTC Go to previous messageGo to next message
Hey guys,
I'm having trouble with plug-ins.
Apparently, I'm supposed to save the plugins (.rb) into the C:\Program Files\Google\SketchUp\Plugins\. Unfortunately, I can not find that folder on my computer.
I hope this is not going to be one of those "I'm retarded" moments.
[Updated on: Thu, 15 December 2011 00:35 UTC]
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40272 is a reply to message #40271 ] Thu, 15 December 2011 00:34 UTC Go to previous messageGo to next message
It should be there, but if not then you'll have to make one. Restart the program , and viola, plug-ins are loaded.
BTW, try to keep the language family-friendly here, Yoni. Recent posts are only a click away from the main page. Embarassed
Let us know if you need any more help!
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40273 is a reply to message #40272 ] Thu, 15 December 2011 00:45 UTC Go to previous messageGo to next message
Aaeron,
Sorry about the language, edited it out.
Can you explain how I would create the folder to the sketchup program?
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40274 is a reply to message #40273 ] Thu, 15 December 2011 00:54 UTC Go to previous messageGo to next message
I'm assuming you were able to find the Sketchup folder using Finder/Explorer?
The only other thing that could be holding you back here could be that the actual path might be "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins", as it is on my computer.
Re: After uploading a file from thingoverse or sketchup, I can't manipulate the individual parts. [message #40279 is a reply to message #40274 ] Thu, 15 December 2011 02:27 UTC Go to previous message
No Message Body
[Updated on: Thu, 15 December 2011 03:05 UTC]
Previous Topic:Help with exporting from C4D
Next Topic:empty output issue
