Home » Community » Work in progress » How sturdy will this be?
How sturdy will this be? [message #35982] Wed, 05 October 2011 20:04 UTC Go to next message
avatar ohaple  is currently offline ohaple
Hi, I'm pretty new to shapeways, and after getting the runaround from a cocreator, I decided to just design my own using the 3d popper. http://www.shapeways.com/model/350579/aj___ah_try_2.html?gid =ug
I can probably make the piece a little thicker (thicker lines, not depth) but I was looking for feedback, with this sterling silver pendant be reasonably strong? Good enough for Jewelry?
  • Attachment: pendant 2.jpg
    (Size: 44.44KB, Downloaded 92 time(s))
Re: How sturdy will this be? [message #36178 is a reply to message #35982 ] Fri, 07 October 2011 20:08 UTC Go to previous messageGo to next message
avatar cadalu  is currently offline cadalu
Well I'm not one to give 3D advice, but I've been experimenting a lot with little swirls and printing rejections. I would suggest downloading netfabb for free and measuring the smallest parts of your model to make sure they line up with the 3D design rules - http://www.shapeways.com/design-rules/silver - 0.6mm. I've found the tapered part of my swirls often fallbelow that number leading to a rejection. You could redraw or thicken any parts that fall below that number and repop/remodel and you'll be set.
Great pendant and good luck!
Re: How sturdy will this be? [message #36180 is a reply to message #36178 ] Fri, 07 October 2011 20:10 UTC Go to previous messageGo to next message
Thanks for your input. Smile
Re: How sturdy will this be? [message #36181 is a reply to message #35982 ] Fri, 07 October 2011 20:12 UTC Go to previous message
As cadula said you have to keep about the .6mm. Other than that you shouldn't have a problem with your design
Previous Topic:Bringing down the price?
Next Topic:Flexed Text Ring
