Home » Support » 3D Design » Seeking advice on making old models ready for print
Seeking advice on making old models ready for print [message #21296] Sun, 05 December 2010 13:49 UTC Go to next message
avatar EvilHomer  is currently offline EvilHomer
I've begun coverting some of my old models so they can printed in 3D. It has proven alot more complicated that I imgained, its whole diffrent set rules and objectives form makeing models just for images. Most of my models are made up of a large number of separate but overlaping objects, some of them simple, some very convoulted shapes.
Stitching all these parts togther into one mesh has proven difficult and time consuming. I use Maya and unfortunatly Mayas booleon function is pretty crap, the only way that works thus far has been cutting out internal geometry and stitching objects together one at a time.
I'm after any advise to speed the process along.
Re: Seeking advice on making old models ready for print [message #21297 is a reply to message #21296 ] Sun, 05 December 2010 14:23 UTC Go to previous messageGo to next message
avatar Eeppium  is currently offline Eeppium
you can work around boolean by making the seperate objects hollow + solid and connecting them together with small "windows"
I´ve used this few times and it has saved many crashes caused when booleaning together multiple complex or simple shapes.
and it keeps the mesh clean.
here´s an obj file for clarification.
Re: Seeking advice on making old models ready for print [message #21319 is a reply to message #21297 ] Mon, 06 December 2010 12:22 UTC Go to previous messageGo to next message
I'm not sure I get you, are you saying that the object doesn't have to be a single unbroken mesh , it can be made up of a number of separate meshes so long as they themselves are unbroken?
Do you mean that your example is printable as is?
If thats true then it would indeed makes things vastly easier.
Re: Seeking advice on making old models ready for print [message #21321 is a reply to message #21319 ] Mon, 06 December 2010 12:25 UTC Go to previous messageGo to next message
avatar Drawn-Steel Hero  is currently offline Drawn-Steel Hero
If you've got multiple meshes overlapping, then Shapeways' software will automatically merge them, so you don't have to worry about that. As long as each individual mesh is watertight, and you don't have any parts below minimum wall-thickness, you should be fine.
Andy
Re: Seeking advice on making old models ready for print [message #21322 is a reply to message #21296 ] Mon, 06 December 2010 12:42 UTC Go to previous messageGo to next message
Exactly my point Cool
and yes that file should be printable as is
Re: Seeking advice on making old models ready for print [message #21323 is a reply to message #21321 ] Mon, 06 December 2010 12:43 UTC Go to previous message
Thats awesome. Thank you both for the help.
Previous Topic:Help on ring model
Next Topic:Light poem/napkin ring
