Home » Support » 3D Design »
Complex assemblies
Complex assemblies [message #12881] Sat, 15 May 2010 09:57 UTC Go to next message
avatar gomi  is currently offline gomi
I what to built a set of gears in a single printing, but when I have tried it has not worked.
Basically I want 2 interlocking rings, and it looks like it can be done from the examples.
With Blender does is have to be a single object? Or can I create the cog, then add the framework.
Re: Complex assemblies [message #12984 is a reply to message #12881 ] Tue, 18 May 2010 23:39 UTC Go to previous message
avatar esnoeijs  is currently offline esnoeijs
You can print fully functional mechanical constructs in 1 go. However, you have to keep a very close eye at the specifications of the material you want it printed in. If two parts are too close together they will be fused together.
There is a lot more info available on the tutorials page.
http://www.shapeways.com/tutorials/index
Take a look under "Advanced tutorials: mechanical parts & designing for 3D printing"
You can also get a feel for it by looking at a few models from the 3D parts database.
http://www.shapeways.com/themes/3dparts
There are a few mechanical parts there. You can download them and have a look.
Previous Topic:How to hollow objects?
Next Topic:Drain hole width
