Shopify Csv Download Is Down
Discussion in 'Shapeways Shops' started by bwterrainforge, Jan 5, 2024.
Tags:
  1. bwterrainforge
    bwterrainforge Well-Known Member
  2. MitchellJetten
    MitchellJetten Shapeways Employee CS Team
  3. bwterrainforge
    Hi @MitchellJetten this finally worked saturday. The download request comes from the shopify app link.
    Also as mentioned a few months back the downloads are badly formatted and shopify has a hard time processing and it takes many hours to process where it use to take a few minutes. If I need to chunk the download, it will make a slow process very very painful.
    Here is the shopify response email
    The product CSV file that you started importing at January 6, 2024, 11:39 pm is now complete.
    • 974 products were successfully imported
    • 27 products were ignored because they already exist in your store
    To import products that couldn't be updated, fix any errors in the CSV file and try importing it again.
    Ignored:
    • Line 741: ignored because it did not contain product data
    • Line 7477: ignored because it did not contain product data
    • Line 7851: ignored because it did not contain product data
    • Line 7917: ignored because it did not contain product data
    • Line 7948: ignored because it did not contain product data
    • Line 7949: ignored because it did not contain product data
    • Line 8485: ignored because it did not contain product data
    • Line 10574-10577: ignored because it did not contain product data
    • Line 10578-10581: ignored because it did not contain product data
    • Line 10582-10585: ignored because it did not contain product data
    • Line 10586-10589: ignored because it did not contain product data
    • Line 10590-10593: ignored because it did not contain product data
    • Line 10594-10597: ignored because it did not contain product data
    • Line 10598-10601: ignored because it did not contain product data
    • Line 10602-10605: ignored because it did not contain product data
    • Line 10606-10609: ignored because it did not contain product data
    • Line 10610-10613: ignored because it did not contain product data
    • Line 10614-10617: ignored because it did not contain product data
    • Line 10618-10621: ignored because it did not contain product data
    • Line 10622-10625: ignored because it did not contain product data
    • Line 10853: ignored because it did not contain product data
    • Line 10906-10909: ignored because it did not contain product data
    • Line 11027: ignored because it did not contain product data
    • Line 11222: ignored because it did not contain product data
    • Line 12584-12585: ignored because it did not contain product data
    • Line 13382: ignored because it did not contain product data
    • Line 14512-14516: ignored because it did not contain product data
  4. bwterrainforge
  5. bwterrainforge
    This is working now using the offset, but manually stitching the files together makes this a tedious task. You need to stitch the file together as it takes hours for you file to load as its badly formatted according to Shopify
  6. bwterrainforge
