40 cm model for under $500
40 cm model for under $500 [message #50243] Fri, 22 June 2012 23:16 UTC Go to next message
avatar dakrause  is currently offline dakrause
Greetings,
I would like to hire someone to take my STL file and print a 40cm model for under $500. I welcome suggestions on finding the right person and the methodology to be used(breaking up into parts, etc).
The full-size STL file(210MB) can be downloaded here:
http://www.thingiverse.com/thing:25418
A screenshot is here:
http://i47.tinypic.com/nr0yew.jpg
Any suggestions?
Re: 40 cm model for under $500 [message #50245 is a reply to message #50243 ] Fri, 22 June 2012 23:33 UTC Go to previous messageGo to next message
Maybe...
Try this. (start at step 4)
Re: 40 cm model for under $500 [message #50248 is a reply to message #50245 ] Sat, 23 June 2012 01:07 UTC Go to previous messageGo to next message
40cm tall would be a scale of 0.00446729216202421942445641430561
the volume as drawn would be over 4000cc.
$0.125/cc is not likely to hapen. if you hollow it to 3mm thick and keep triangle counter under 1000000 you may get your price point
Re: 40 cm model for under $500 [message #50347 is a reply to message #50248 ] Mon, 25 June 2012 18:32 UTC Go to previous messageGo to next message
Commercially, a print at that size will be difficult to make happen at the price you are looking for.
I suggest asking on the Makerbot or Ultimaker google groups if someone near you would be willing to print this. A home printer should use something near $50 or so in material to print at the requested size with a reasonable amount of infill, so you should be able to use the rest of your budget to rent machine time... a print that large will need to be broken up into pieces to print on a domestic machine, and the printing will take a whole weekend (at least) to print.
If you go this route, make sure you find someone with a well-sorted & calibrated printer (ask to see some examples of both 'good' and 'failed' prints, to get an idea of what you can expect). A job this large is likely to be a bit over the head of a new printer operator; there is plenty of time for things to get out of alignment or otherwise go wrong.
Re: 40 cm model for under $500 [message #50653 is a reply to message #50347 ] Sat, 30 June 2012 19:56 UTC Go to previous messageGo to next message
No idea on the price.
http://www.shapeways.com/forum/index.php?t=msg&th=9948&a mp;start=0&
Re: 40 cm model for under $500 [message #50698 is a reply to message #50653 ] Mon, 02 July 2012 12:02 UTC Go to previous messageGo to next message
Thank you for your suggestions. I understand that I need to reduce the resolution of the file to something that can be managed by the printers. The Unigraphics (Siemens) software can reduce the scale, but it apparently cannot reduce the resolution of the STL file.
How can I reduce the resolution of the STL file?
Re: 40 cm model for under $500 [message #50747 is a reply to message #50243 ] Tue, 03 July 2012 15:42 UTC Go to previous message
You may be able to reduce the resolution of the STL file by using the decimate modifier command in 'Blender' http://www.blender.org/
http://wiki.blender.org/index.php/Doc:2.6/Manual/Modifiers/G enerate/Decimate
Previous Topic:Interesting, quick PAID project for experienced 3D designer
Next Topic:spartacus crixus necklace
