Hi again.
I read on the material page that I cant have such thin walls on the metal printing, so I have a revised idea. Instead of sleeving from the inside, I can sleeve from the outside with metal.
The inside I can either fill the gap with liquid polyurethane and use the M12 bolt to get it smooth. Or I could use a very simple 3d printing in strong and flexible polished.
The revised idea is to get the sleeves on the outside of the flanges on this bushing:
http://www.qa1.net/qa1_motorsports/drag-and-street/suspensio n-accessories/shock-mount-accessories/bearing-kits.html
It's a tad complicated to explain, so I will mspaint it.
If someone wants to quote me the design (personal use). I could also use an "internal" sleeve with OD: 13mm, ID. 12MM and length: 25mm.
OUTER DIAMETRE 20mm for the one in the picture
