need : 3d model of a DOUBLE HELIX SPRING [message #44761] Fri, 02 March 2012 09:08 UTC |
can someone create for me a "DOUBLE HELIX SPRING" model (like the dna spring) made out of stainless steel\music wire
round circle (like a ring) at the bottom and top , one wire spiral from the bootom side circle , and second wire spiral from the paralel side bottom circle , both connected also at the top ring. measurments about 100mm high , about 40mm outside diameter , wires thickness about 2mm , distance from one spiral to the other about 3mm
how much for such job?
thanks !
[Updated on: Fri, 02 March 2012 10:40 UTC]
| Re: need : 3d model of a DOUBLE HELIX SPRING [message #44766 is a reply to message #44761 ] Fri, 02 March 2012 12:15 UTC |
yes though shapeways may refuse 2mm spring in stainless. 3mm is minimum spec you can try though. will pm you the part.
| Re: need : 3d model of a DOUBLE HELIX SPRING [message #44767 is a reply to message #44766 ] Fri, 02 March 2012 12:26 UTC |
3mm will be fine also
| Re: need : 3d model of a DOUBLE HELIX SPRING [message #44768 is a reply to message #44766 ] Fri, 02 March 2012 12:32 UTC |
the address is not working.. it says Invalid model id: 92162
| Re: need : 3d model of a DOUBLE HELIX SPRING [message #44770 is a reply to message #44768 ] Fri, 02 March 2012 12:54 UTC |
Sorry deleted 1 to many digits should be a2 or 3 in front of number
| Re: need : 3d model of a DOUBLE HELIX SPRING [message #44771 is a reply to message #44770 ] Fri, 02 March 2012 12:58 UTC |
doesnt work.. can you send the address again?
| Re: need : 3d model of a DOUBLE HELIX SPRING [message #44772 is a reply to message #44770 ] Fri, 02 March 2012 13:03 UTC |
2 in front of the number is invalid and 3 in front of the number says : Sorry, you don't have permission to perform this action
