rotating pill box
rotating pill box [message #3733] Fri, 03 April 2009 13:54 UTC Go to next message
avatar Gijs  is currently offline Gijs
I designed a little pill box, for anti-conception pills. The box is ring shaped and can contain 21 pills (if you count correctly, you will see there are 22 slots, therefore the box doesn't require a closing cap Smile
The clearance between the parts was 0,1mm . It required a bit of forward and backward turning to make the ring rotate, but after that, it works surprizingly well.
index.php?t=getfile&id=453&private=0
index.php?t=getfile&id=454&private=0
index.php?t=getfile&id=455&private=0
index.php?t=getfile&id=456&private=0
index.php?t=getfile&id=457&private=0
www.studiogijs.nl
Re: rotating pill box [message #3739 is a reply to message #3733 ] Fri, 03 April 2009 14:54 UTC Go to previous messageGo to next message
I like it! Too bad you didn't enter this in the moving part contest Sad
I would have some concern about using it, as Shapeways has stated they cannot yet guarantee the "food safety" of their plastics. Let me just caution you, before you use it, to make sure absolutely all the powder is out of the model. It's very hard to tell sometimes, because powder can stick quite tenaciously in corners. Take a finger nail cleaning brush to it while it is dry, and then under running water, and then dry again just to be extra safe.
Great model and great thought process!
-Whystler
Re: rotating pill box [message #3767 is a reply to message #3739 ] Sun, 05 April 2009 08:32 UTC Go to previous messageGo to next message
avatar tempusr15819_2511ab8a5d7  is currently offline tempusr15819_2511ab8a5d7
Cool object !
Nevertheless, wsf (PA 2200 Fine polyamid) is biocompatible, so no problem...
Re: rotating pill box [message #3768 is a reply to message #3767 ] Sun, 05 April 2009 09:50 UTC Go to previous messageGo to next message
avatar frankbuss  is currently offline frankbuss
Emm@nuel wrote on Sun, 05 April 2009 08:32
Maybe for a pill box it is no problem after good cleaning, because the material itself may be safe, but you can't be 100% sure, because of the additional materials used during printing.
Re: rotating pill box [message #3777 is a reply to message #3733 ] Mon, 06 April 2009 11:17 UTC Go to previous messageGo to next message
Thanks!,
about the safety: yes I did clean it thoroughly. I am not sure about using it, because I expect this material to absorb water. This means that the pills, that have a sugar like layer on the outside, to become sticky.
I am not so afraid of food safety though, I think we eat a lot more toxics we don't know of every day...
www.studiogijs.nl
Re: rotating pill box [message #3788 is a reply to message #3768 ] Mon, 06 April 2009 14:27 UTC Go to previous messageGo to next message
avatar psau3  is currently offline psau3
frankbuss wrote on Sun, 05 April 2009 09:50
Isn't WSF formed by SLS, so the support material is just more of the same inert powder?
So far, I'm resisting the urge to chew my WSF offcuts until we get the final word. Smile
Re: rotating pill box [message #3791 is a reply to message #3788 ] Mon, 06 April 2009 15:31 UTC Go to previous messageGo to next message
Yes, it may be inert, but it's plastic powder folks Smile You don't really want to breath or ingest it, because it breaks down much slower than things we normally put in our mouth and airpipes. The could easily cause irritation or immune responses in the lungs and throat.
-Whystler
Re: rotating pill box [message #3835 is a reply to message #3777 ] Tue, 07 April 2009 14:23 UTC Go to previous message
Gijs wrote on Mon, 06 April 2009 11:17
Very true. Hormones, antibiotics & heavy metal in the water, low-grade non-stick coatings, various unpleasant compounds leaching out from food storage inners & bottles, etc. Putting it into perspective, it's all relative. Would WSF be potentially less harmful than the solvents and organic volatiles we work with? Cyano accelerator?
I'm not being deliberately naive when I say I'd consider chewing WSF. It might be better for you than the petrochemical base and artificial sweeteners in the gum I'd otherwise be consuming.
Hey kids, don't chew WSF. Have an apple instead. Wink
Previous Topic:Bell Mouth Intake
Next Topic:level 5 sierpinski !
