Hello all,
I am currently designing a model train Ho scale. I would like to print one of the part in stainless steel to get sufficient weight but I have a question on the tolerance of Stainless Steel printing.
The design rules page says: "Parts are accurate within 2 mm of the design. Depending on how much binder is deposited, parts may shrink or grow slightly during the printing process. Binder deposits should vary depending on the geometry of the Shape in a build. Since Shapeways prints a variety of shapes in one batch, some parts might come out inaccurate."
- Does this mean that the tolerance is +- 2mm? In other words, my part can be up to 2 mm longer or shorter (imagining a rectangular part) This is a lot!
- Can this +-2mm can be in any dimension of the piece? +2mm in one direction, -2mm in another dimension?
- Do I also understand that this tolerance depends on the printing, meaning that if I reprint a part, the second one could be up to 4mm different in size from the first part? (making spare parts impossible!)
Also, I attached a step file of the part I would like to print. I guess the small rectangular holes (for attachment of the model bogies) are too small to be printed in steel? And if it could be printed but with a +-2mm tolerance, it would be unusable.
Thanks in advance for your answers.
