Hi Ana, cheers!
As for the technical info the lamp is in two pieces, the top part lifts off the base. Inside the base there is a fitting for a 30mm lampholder.
Lampholders have two parts, the main section for the bulb and a collar piece which screws into it. I'd pass the power cord of the lampholder through the stem of the base part and feed the screw thread of the lampholder up through the ring in the base of the lamp, you can then screw on the lampholder collar from above to hold everything in position.
You'd need to cannibalise a lamp for the internal parts.
Hey Ray, cheers mate. I like the white if I'm honest, but yeah red sounds tempting. I haven't ordered this one yet but I've put it in for the ICFF contest, maybe I'll get lucky.
