I tried sanding the ends with a coarse Flex-I-File Flex Pad sanding stick and got a nice smooth surface after a few passes. It would take a LONG time to do the sides of the coil hood with the sanding stick so I thought I'd try using my Dremel tool with a small grinding stone in it (
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/ AttachmentsDetail.aspx?pid=85602 )
Full size image is 4.5x larger than the actual part.
It took about 40 minutes of sanding for each hood; you need a light touch with the Dremel tool (at the slowest speed setting) to keep from removing too much paint at once. I used a diamond-coated jeweler's file to gently sand the lifting bail on the top of the hood. Two or three passes usually was all it took to smooth out a surface.
