| Emachineshop.com CAD Conversion [message #20320] Wed, 10 November 2010 18:48 UTC |
I'm having a problem with my CAD program, namely Emachineshop.com's free CAD software. I've been able to export .STL files in the past, yet for some reason, when I try to export something now, it fails. I can render them just fine, so I know the designs are good, it's just not working. I suppose I got what I paid for, but I'm still at a loss as how to get usable files.
The only thing I can export my drawings as are .DXF. When I import them into Blender or Accutrans, they're just planes, rather than a modeled
I'm out of ideas as to what to do next.
I was able to nab the XML files the CAD uses for the conversion, but I can't translate that into a usable Shapeways file either.
.DXF file is attach, if anyone has a clue how to help. Any ideas would be appreciated.
Attachment: melta2.1.DXF
(Size: 589.74KB, Downloaded 94 time(s))
| Re: Emachineshop.com CAD Conversion [message #20324 is a reply to message #20320 ] Wed, 10 November 2010 19:46 UTC |
Does it have a default format that you can put up? I'm downloading the software now to see what I can asses.
| Re: Emachineshop.com CAD Conversion [message #20328 is a reply to message #20324 ] Wed, 10 November 2010 21:17 UTC |
The default format is .EMS, which I'm guessing is a proprietary format based off .dxf files. That's just a wild guess, as the file sizes are fairly close.
Other than the fact it can't export worth a darn with curved models half the time, it's well worth the download.
Attachment: melta2.1.ems
(Size: 306.93KB, Downloaded 54 time(s))
[Updated on: Wed, 10 November 2010 21:19 UTC]
| Re: Emachineshop.com CAD Conversion [message #20365 is a reply to message #20328 ] Thu, 11 November 2010 13:38 UTC |
I'm having no luck getting it to export, but I do love that it may be able to export iges. I'm looking at it in eMachineshop's 3D view and the bottom 2 appear to have issues in the handle.
It appears the problem may be slight misalignments in the wires. I don't know how to use the software so I cant try to fix it. But I did draw it in my software using the dxf as a guide. But it won't import into the emachineshop software... Oh well at least here's an stl you could upload.
Attachment: melta2.1.stl
(Size: 1.57MB, Downloaded 56 time(s))
[Updated on: Thu, 11 November 2010 14:18 UTC] The Mad Moder
| Re: Emachineshop.com CAD Conversion [message #20431 is a reply to message #20320 ] Fri, 12 November 2010 13:36 UTC |
Yea the model I made, I tried to import it into emachineshop by iges and sat. No luck, it gives you a pop up that says it currently doesn't import arches...
