Thank you!!
You are full of thoughtful ideas!! I appreciate you giving my problem your input!
Yes, the needles go all the way through the tools, do need to be removable and are held in place just by friction - the holes are currently formed by actual needles so perfectly sized (the needles are 15 gauge, 1.83mm or 0.0720 inches in diameter). Needle felting tools are used primarily on wool fiber - and it is possible to felt that to the point that it becomes very hard - but that isn't a desirable quality in needle felting.
https://www.flickr.com/photos/prittens/
The aluminum blocks just hold the needles in the correct positions. The size of the blocks isn't critical (they're just a bit larger than my tools)- they just have to have the holes in the correct arrangement plus have a recessed area so that the crank on the top of the needles can be recessed into the block so the block sits flat on the counter. That recessed depression also needs to be large enough so that I can use needle nose pliers to remove the needles from the newly cast tools.
It's a 2 part mold setup - the silicone molds were made to also hold the aluminum blocks and that part of the mold start deteriorating more quickly than other parts. After a while, my molds start deteriorating the two part mold is holding up better, but it can be pretty wonky too. The top of the tool is completely exposed in the mold - so I have a decent size hole into which to pour the resin.
I'd actually prefer the name to be recessed rather than relief - the name ended up being relief on the last blank I made to create the molds.
My resin sets up in 15 minutes. There is no time for degassing. When the resin is new, it casts very well - and the minor bubble that you spotted on the one image wouldn't count as a bad cast. Obviously I would really like to have perfect casts every time - which is again why I was looking at 3D printing.
Some of the size of my current tools might be reduced, BUT one of the reasons that my tools are good is they are comfortable to hold - a certain amount of thickness between thumb and finger is necessary (more than what you imagined in your mockup).
I don't want to spend my time working with resin and casting these things, but people want them and I recently was asked to fill an order for 30 sets.
I'm not looking to make a lot of money off of these and the estimated price is not terrible - I was just hoping it would be less. It would be so nice to have them made, all look beautiful and do what they need to do.
I have errands to run!
THANK YOU!!!
Jeanne
