I have been searching the internet for this for a while now, but couldn't find the information I needed. So I decided I would do an experiment myself.
First, what is the problem? I want to print a part for use on my motorcycle, which will be exposed to the weather. My preferred material would be ABS, but ABS prints apparently are quite expensive (my part turned out to be over 120 euo's on i.materialize). So I tought of SLS as an alternative (30 euro's), which would certainly fit the bill in terms of accuracy and strength for my purpose.
It is water permeable, but my part does not need to be water tight. However, Nylon (polyamide) also absorbs water. For this reason, 3D printing websites often state that Nylon (strong&flexible on shapeways) is not suited for outdoor use. But nowhere can I find why this is a problem. What exactly happens to my part when it absorbs water? (even the shapeways team couldn't tell me, as they didn't do any tests for this). For this particular part it is only important that it retains its strength and doesn't change in size dramatically (a bit is acceptable).
So I decided to do a simple test myself, on an sls part I had lying around which wasn't going to be used anymore. It's a pair of glasses, with actual glass fitted into it, a couple of hinges and snap fits. I wanted to submerge it in water for a day. If the glass still fits, and the hinges and snap fits still work properly afterwards, that would mean the part did not increase in size significantly due to absorbing water. (at least not significant enough for my purpose). The snap fits and legs are rather slim and flexible, so that would be a good "measurement" for stiffness and strength as well. (not a very scientific test, but good enough for my purpose).
So after a bit more than 24 hours of being submerged, I checked on the part and it turns out fine! In fact not much at all seems to have happened. Flexing the legs is no easier than before, and the snap fits still snap as intended, so stiffness and strength did not change noticeably. The fit for the glasses in the frame is still as tight as it was before, no tighter or looser. The hinges still work perfectly as well. So size doesn't seem to have increased significantly either.
So the water did not seem to have a drastic effect on the material. I did not measure it before hand, so it actually might have increased in size a bit due to the water absorbtion, but I can't really tell for sure; but the effects are so marginal that all parts still fit together like nothing has happened.
Since the part survived the first 24 hours, I decided to leave the part submerged a bit longer to see what happens after another day or 2, but I suppose that is beyond what the part will be exposed to outdoors anyways (not being submerged). To be continued...
All in all, I think I'll just print my motorcycle part in SLS and test it in real life. The worst that could happen is that it expands to much, and I cannot remove it without breaking it
(which will not cause any life threatening situations
) and with effects this marginal, it definitely should keep working properly over time.
