Lightwave VRML export
Lightwave VRML export [message #13034] Thu, 20 May 2010 10:30 UTC Go to next message
avatar Stephen.Tarheel  is currently offline Stephen.Tarheel
Good morning!
I tried uploading VRML files created with lightwave last night/this morning and I keep getting the "
The fileformat of your object cannot be processed by our software. Please investigate the problem and try again. " error message. Originally I thought this was due to not using a JPG for the texture file, I've corrected that and used both the embedded and non-embedded options for exporting the VRML file.
Does anyone have experience exporting VRML files from Lightwave and might know what's going on?
-Stephen
Re: Lightwave VRML export [message #13035 is a reply to message #13034 ] Thu, 20 May 2010 10:33 UTC Go to previous messageGo to next message
Good morning !
I don't really know lightwave, but you can download the free Meshlab and use it to check out the vrml file.
Basically vrml is a textfile so you can also use a text-editor to see if anything looks weird.
Stijn
Re: Lightwave VRML export [message #13037 is a reply to message #13034 ] Thu, 20 May 2010 10:47 UTC Go to previous messageGo to next message
Hi there,
I also have not tried exporting with lightwave,
but make sure the file is version .97 or version 2
version 1 does not work.
with 3DS Max you have to ensure that the image file used to map the image is in the same folder as the VRML file, that you then zip together to upload to Shapeways
I hope this helps..
cheers
Duann
Duann Scott
Re: Lightwave VRML export [message #13040 is a reply to message #13034 ] Thu, 20 May 2010 13:10 UTC Go to previous message
avatar ChrisWilmer  is currently offline ChrisWilmer
I got that error a few times when, believe it or not, parts of the mesh were intersecting... which has nothing to do with the file format at all!!!
So, it's probably a problem with the actual model, rather than the file format. That's my guess!
Previous Topic:Got really stuck again.
Next Topic:Showing design in 3D
