Hi.
In your experience I want to know the ideal relationship between width and deep of letters, to be printed in Gold Plated Brass. I've uploaded a model with deeper letters than its width -1.5 mm depth, for 1 or 1.2 mm thick-, and the wall thickness check marked it as OK. It will be printed OK or it will be refused?
Another question. I've designed and printed different models -with letters- but each model comes out with different sharpness, so I don't know what will be the exact relationship to reach the best results -well defined raised letters-. The manual polishing and plating process results in different finishes so I don't know the exact result until I got it on my hands! Any way to have a more precise result?
I know that's a different material but I've just received two identical parts in polished white plastic, and one of them has less detail!!! They look totally different for the polishing process -one sharper, the other one dull-. The polishing process must be best controlled.
Many thanks for your help.
Best
