I neglected to mention that sometimes (infrequently, thank goodness) there's a heavy wax buildup on some surfaces- a lumpy white surface, which I believe is what you're describing.
After doing the alcohol thing, I always lightly sand my parts- since I do railway models, I need a good smooth surface finish.
If the layer is a little too lumpy to sand down, I'll scrape it off with a single edge razor blade or hobby knife, held at a steep angle to the part. Pull the blade back, so the sharp edge is dragging across the surface rather than cutting into it.
I often encounter surfaces which are nice and smooth, but are white- in those cases, I just do my light sanding, typically starting with 400 grit emery cloth and finishing with 800 grit.
My parts all receive a light coat of acrylic paint, which allows me to ensure the surface and detail quality is good, after which I finish assembling and painting the model.
I hope this will help!
Steve Hunter
