So I don't know about impossible... but certainly experimental - that is part of what makes this interesting!
Shapeways has a new plastic/process - check out elasto-plastic -
https://www.shapeways.com/materials/elasto-plastic?li=nav
The SLS process allows for more open structures to mesh around the shape of your foot - we aren't bound to standard printing support limitations.
Here is an example of the SLS printing process in video:
https://www.youtube.com/watch?v=wD9-QEo-qDk
That said I have not worked with this material - I can't comment on its appropriateness for this application as it is new but we have a couple of things going for us. It is an off white color - so close as a base if you want to have it airbrushed to match your skin tones. It is flexible and stretchy, so it should provide a friction mesh to your foot. It also includes a polishing process which should leave really smooth, natural looking lines on our details. The thicker you go with this plastic - the firmer the structure -so we can have control over the flexibility of the toes, probably go solid on first run, and then scale back from there if you wanted more flexibility. Reality is -given the weight the toe will take, I don't think we can go too firm with a flexible plastic.
If you are interested in moving forward with this please PM me. If you could start putting some pictures together of your foot we can look at doing some rough modeling of it. For some direction on this please visit our web site at
http://www.thelostpiece.com/order.htm - that has directions for capturing dimensions.
Sam
