Hi guys,
I am trying to print a 3d brain in the full color sandstone, so I cannot use an STL file (which does work fine, btw).
In sketchup, it's a solid object, in one group, and I've tried every COLLADA option that there is.
Here is what I've tried, and the error messages that I've received:
I usually get this error message:
We're unable to process this file. Check your file for errors and click 'Update File' to upload a new version.
Model failed during repair.
The final model was empty.
Perhaps it's too small?
Following up on that, I tried changing the model from mm to m. I've tried increasing the size of the model several orders of magnitude. Increasing the size of the model by a huge amount results in this (or a similar error message).
Rescale from meter to mm.
Model failed during repair. The final model was empty. Perhaps it's too small?
Increasing it more sometimes leads to messages like this!
Automatic rescale failed. Model is not within acceptable bounds in any unit. When rescaling to units in:
- millimeter, model is 53.6196 x 40.01463 x 41.97557 m
- inch, model is 1361.93787 x 1016.37158 x 1066.17932 m
- meter, model is 53619.60156 x 40014.62891 x 41975.56641 m
Ahah, who cares if this thing is the size of the earth in sketchup??? As long as Shapeways can figure it out, I'm happy, but, alas, no. Reducing it by 100x, does at least result in *something,* but it's not useful as can be seen in the semi-successful-upload screenshot.
What I don't understand is why it isn't working. It opens correctly in both Meshlab and blender (I don't know how to use them, but it does open correctly in them), and it displays in the mac preview window - so why isn't it working???
I've attached the sketchup file for you guys to check out - not much point in attaching failed COLLADA files, but I'll attach that last one just in case you want to see one. That one was with some of the weirder export options selected (export both faces, etc).
Please help.
-Frederick
