I whish to make a pendant lamp in the shape of a UFO.and I hope it will be the first of a serie.
The materials will be shelled plastic and shelled metal.
I can provide som rather crude inventor designs to show you what I have in mind.
It would be nice with some technical advice ,as, even though I am studying to be a welder, I am not sure if the designs are possible using a CNC machine.
The design will be in two parts assembled using a screwing device ( you would be able to unscrew the object like a coke bottle in order to replace the light bulb inside ).
you will have to go from a picture and get as close as you can to the dimensions ( the only dimension I have is the base of the object )
I am looking for something classy and not the usual cheesy/cartoony appearance that most UFO objects are designed as.
English is not my native language, and there are some technical definitions that I simply do ot know in English.
Thank You,
Boris
