Home » Support » 3D Design » Printing a surface made up of thin faces
Printing a surface made up of thin faces [message #54913] Fri, 05 October 2012 03:52 UTC Go to next message
avatar evouga  is currently offline evouga
I recently published a paper on designing surfaces that are stable under gravity: www.cs.columbia.edu/cg/pdfs/188-selfsupporting.pdf
I would now like to take an example of a surface designed on the computer, and realize it in real life. In particular, I would like to print the surface on the right of Figure 1.
To do this I would need to print two parts:
a) A single (hollow) volume, representing the space between the surface in Figure 1 and the floor. This piece will be used as a scaffolding for constructing the surface.
b) All of the faces of the surface. As you can see, there are about 100 pieces. I will then assemble the pieces into the structure shown in Figure 1.
Can this be done using shapeways? Can I upload the pieces as a single .obj file containing disconnected volumes? Is there a way of easily labeling each piece (to ease putting the surface together afterwards)?
Re: Printing a surface made up of thin faces [message #55008 is a reply to message #54913 ] Sun, 07 October 2012 19:06 UTC Go to previous message
What size did you actually want? Is it a scaled model?
The maximum 'Bounding Box' for SWF is 660 x 350 x 550mm
Have you got a .obj file of the structure?
jacantdesign@gmail.com
Previous Topic:Why is this cube so exspensive
Next Topic:HELP - Sketch up - Manifold edge issue.
