You didn't set the model to public so that we could see it.
One answer to your request is to lookup the "Ball Pivoting Algorithm", one paper on it is here:
http://www.research.ibm.com/vistechnology/pdf/bpa_tvcg.pdf
The other answer: (non-programmers
stop reading here!)
You can't do the entire surface in a single step. You must treat each triangle separately. For every triangle you have currently, it must become a solid with "thickness", rather than a single surface. Then, add all the solids together using Constructive Solid Geometry (CSG). May I suggest you spend some time with
Openscad? It has CSG algorithims it uses, and the source is freely available.
Steps:
For every triangle:
-Compute the surface normal to your triangle.
-Add a new triangle A,B,C some delta distance away from the original (half of the desired thickness) along the positive surface normal.
-Add a new triangle with the opposite "winding order" (C,B,A) offset in the negative surface normal direction. We'll call this triangle D,E,F
---This gives you the two "plates" (top and bottom) for the new solid.
-Now, work around the edges of the plates, filling in the "side" triangles: (A,B,D) and (D,B,E) and so forth.
-Each final solid will be made up of 8 triangles instead of just one.
Once all the new solids have been generated, use CSG-union to combine all them into a single solid.
Hint: if you produce all the separate solids into a single STL, then Netfabb-Cloud has a free service to union them all together.
