I found another mess up in the materials transition, kind of sort of, since I was doing something in a non standard, non Shapeways authorized way in the first place. But it always seemed to me that we should be able to sell our own CustomMakered files as a courtesy to less tech savvy customers who were having trouble using the tool, or when temporarily modifying customization parameters for a certain customer.
I had some guitar picks (from my own CustomMaker based product) I personalized using CustomMaker and at the time was able to edit the CustomMaker generated product and convert it into a product with a mark-up. It was a little hosed up but it was visible and sellable in my shop; even though it was appended to the end of the shop and could not be display ordered like a regular product.
It turns out the item is still in my shop but now it has an invalid link which provides a blank page. It's also impossible to edit the product now, for example to disable the product or do anything else. I think this is the result of the material option codes changing in the latest transition. In other words red SF seems to have had a material code of optionId=60839364 and now the versatile red plastic whatever is optionId=21100217. If you change the material code in the old address to the new one the selling page does indeed appear. Here's an image capture of my shop that shows the product at the end of my shop.
Defective link in store:
https://www.shapeways.com/product/9...style-0001-1-4mm-engrave-3x?optionId=60839364
Corrected link with revised material code:
https://www.shapeways.com/product/9...style-0001-1-4mm-engrave-3x?optionId=21100217
(Alternately removing the material code completely brings up the page as well.)
Another interesting link is the one from the original order status page which has a different option ID but also leads to a blank white page:
https://www.shapeways.com/product/49BGWWRLQ?optionId=59542102&li=ostatus
As I recall that final link from the order status page was the link that provided an edit button that allowed me to set the CustomMakered files as public and for sale. Again removing the material option id from that last link brings up a visible page, but without a product edit button.
Another interesting tidbit is that I can't find valid links for any old CustomMakered products on my older order status pages. They all bring up a blank white page, readable by removing material option, but non-editable. That also means there's also no way to download Customakered geometry files and upload them to new virginal model/product page pairs. I'm not even sure if those items can be re-ordered from the old order status pages. As of now I have not tried reordering an old customized model. Someone might want to check on that.
So my basic problem is that this is now an orphaned, uneditable product. I think that all I could do at this point is to delete the model and
maybe that will delete the model and the product in my shop. However I don't want to delete the model nor do I want to make things worse in my shop. Is there a fix or a simple work around to the problem that I'm not seeing?
