I think my foul mouthed tie and I will try to stay out of the fray.
So in reply to all the above, I'll confirm again, no, I've no interest to start a newco developing novel resins to compete with 3DS or even buy a 3DP to start to compete with SW. That is not where my head is at.
I've great respect for the technical advantage 3DS (and its existing competitors) have in engineering and resin chemistry. And I rather see 3DP being like copy service, where yes, some might have retail grade units at home, but the biggest and baddest boxes that produce the results I seek will be run by service providers.
A man's gots ta know his limitations....
Rather my focus is:
1) Get a crystal clear understanding of WHAT this is.
With that, we can rationally have some assured it is either A) fully correctable by SW/3DS (say SW no longer cutting corners, as @
sozzap23 suggest, or improved 3DS QA/QC batch to batch consistency) or B) the effect is an inherent attribute of the current formula of FXD/FUD and normal exposures (this confirming some fear that the material may not be not suitably stable for all durable application in some conditions - that is unless a new post print process and/or protective finishing is applied.)
Till answers are forthcoming, I simply don't feel as much need to focus on building a shop predicated on this material, or even prioritize future modeling aspirations that require FXD/FUD, when the next breakthrough in 3DP material might be just a year or two away, and FXD/FUD might become obsolete for my needs.
2A) If the results point to A, then would know to press SW/3DS to assurances they made the needed improvements.
But if B, as I suspect...and the longer it takes to get answers from SW, the more one might imagine it favors a conclusion that the effect is an inherent FXD/FUD characteristic...
2B) Shift my energy to rationally testing various post FXD/FUD print interventions, with the aim to see if we (again, we - the community of SW clients, both shop owners and end users) can test and find rational ways to neutralize this chemical effect with the aim to extend the shelf life one can get from FXD/FUD based models.
>>Until you or anyone else can PROVE that FUD /FXD is unstable which you can't then I suggest you stop trying to fear monger.
Is FUD/FXD unstable?
In some exposures, absolutely.
Drop a part in MEK. Kiss it goodbye.
Q.E.D.
Not a reasonable expectation, granted. But underscores that stability is an attribute of exposure and is not the same for all applications, and stability is not black or white, but a material characteristic that is placed on a range of inertness.
No material last forever in all applications. Not rock (not even diamonds - despite what DeBeers wants us to believe). Not metal. Not wood. Not glass. Not thermoplastics. And certainly not UV cured resins.
So a "stable/nonstable" semantic discussion is nearly meaningless without understanding the applications and shelf life expectations of the end user. Now perhaps @
sozzap23, the buyers of your(absolutely awesome) SW parts are fine building their model, taking a few photos and then chucking it in dumpster. And others use FXD/FUD for getting a rapid prototype or producing an initial pattern for development of molds to cast more durable materials. For these applications, stability without a degradation bloom that may occur after a year on display isn't any issue. But for models with a display duration of 3 years in an environment with some humidity and UV exposure? At this point, with what we are seeing and the little we know about it, if I was a professional modeler and my client was a museum with a long term expectation to display? I simply could not advise they guarantee a FXD/FUD based model will look as good in a few years as it was when delivered. In fact, to be customer focused, I would be sure they were aware that in some cases, some issues have been reported and that the maker of this material still has not been forthcoming about it.
But none of anyone's intent here with us poking SW/3DS for an answers is "fear mongering". Such an accusation is mindless meta. And equally shrill as "Chicken Little" hyperbole demands that 3DS/SW discontinue FXD/FUD immediately.
Anyway, it's Sunday night here in San Diego, and I too have a life to get back to.
