I like this idea BUT I have a couple of issues.
The main issue is that a few of my earrings are designed to work with jump rings in addition to ear wires.
This is for two reasons: (1) One of the designs does not have a hanging ring because I attach a jump ring a certain way and then attach the hook and there is no way to just attach a hook.
(2) A few designs are done the such that the hanging ring is oriented at one angle, the jump ring rotates the earring by 90 degrees, then the hook rotates it back. If it is done with just a hook, the earring is "facing the wrong way" to the viewer
because it is 90 degrees off.
What should I do? Should I submit new design updates so that these earrings can accommodate your hooks-only design? That means that when I sell them I must use only hooks, which I don't like to do because it's easier to handle the earrings with jump rings added and the designs might also dangle better with jump rings.
